For those that bought the Titek Duct
Old Mar 27, 2007 | 04:40 PM
Pooplet's Avatar
Pooplet
Default For those that bought the Titek Duct
Was your template all jacked up? i lined it up and cut out the hole perfectly. The hole was WAY too small, and resulted in me spending 30 minutes shaving off excess bumper trying to make the duct flush. Anyone else have this problem?
Old Mar 27, 2007 | 04:48 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
yep, ive posted it before. The template is way too small. It will not line up with the upper straight area and the lower area that curves around the headlight.
when i got my duct/template i cut the center outta the template and test fit. Conclusion, template too small. Got the varis one tha usnhm350z posts all over the place, opened in paint is fockin huge, print from ms pic manager onto one page and its too small as well.
Old Mar 27, 2007 | 05:07 PM
Pooplet's Avatar
Pooplet
yea that template almost ruined my bumper. The uppper right angle was too steep on the template and my duct hole almost ran into it.
Old Mar 27, 2007 | 07:13 PM
jgxchris's Avatar
jgxchris
i didnt even get one...hahaha
but i found on the forum...
pretty easy after that..
Old Mar 27, 2007 | 09:25 PM
Pooplet's Avatar
Pooplet
Old Mar 28, 2007 | 04:32 AM
davidf's Avatar
davidf
If it matters at all, my Varis template was off also. Trimming is relatively simple so it really is'nt an issue. As long as it's not to big.
Old Mar 28, 2007 | 04:56 AM
MUZZY's Avatar
MUZZY
template was too small so i just made it bigger upwards and to the left..... I think someone fuucked up while making copies!
Old Mar 28, 2007 | 06:03 AM
THE TECH's Avatar
THE TECH
Hmmm...when I've used the Varis one, it is spot on. If anyone got a Titek from me and needs the template, I can send you the Varis one.
Old Mar 28, 2007 | 07:30 AM
MUZZY's Avatar
MUZZY
I dont think they will match... the titek has a sharper angle on the side closest to the headlight and dosnt match the contour of the lights... better to look in person.
Old Mar 28, 2007 | 07:59 AM
jtabraham's Avatar
jtabraham
Sorry for the crude drawing. The varis duct seems to have more defined angles leading up to the front flange, whereas the titek ones are more gradual, with much less distinction. This all leads to the titek duct needing extra trimming to make it sit flush
I recently installed my Titek duct and knew immediately that the included titek template was much too small. I printed off the Varis template using Microsoft Picture Manager --> Print --> Full Page FAX Print (using a full page photo print will make the template too large).
I also knew that the varis template's angles were too sharp for the titek duct, so I cut them more gradual as can be seen in the figure below.
I made the cuts and used the right side as a reference point. From there, I kept trimming the left edge and top edge of the hole until the duct fit flush.
Old Mar 28, 2007 | 08:06 AM
97supratt's Avatar
97supratt
Yeah I had the same problem with the titek one but I trimmed accordingly. I also don't understand why the end diameter is so small. What the hell is the purpose of that thing?
Old Mar 28, 2007 | 08:16 AM
THE TECH's Avatar
THE TECH
To provide a funnel effect to lead the air to a specific point or connect it to a duct.
Old Mar 28, 2007 | 10:41 AM
97supratt's Avatar
97supratt
Well yeah I understand that much, but the opening is quite large and it ends up being very very small. It looks great though. I just wish gruppe-m intakes were a little cheaper, I would sport one.
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
