Airbag light delete
Old Apr 16, 2007 | 09:57 AM
Mc556's Avatar
Mc556
Default Airbag light delete
Is there anyone that can help I posted this in the proper sub fourm with no luck(Did lots of searching too) I just bought and installed a momo wheel with there 350z hub. I talked to a guy at Momo and he said that the supplied fuse goes into the orange connecter. Well no luck the light is still flashing. Can some one help. I called back to momo and they were no help he said" I think thats how you do it" This has not been very much fun the hub fit horrible I had to use a die grinder with a porting bit to get it to fit with the grey connector. Thanks Jared
Old Apr 16, 2007 | 04:42 PM
Mc556's Avatar
Mc556
Someone must know this info? It really sucks that MOMO didn't but this can't be that hard .. It really sucks to have to do the reset each time you find your wrong
Old Apr 16, 2007 | 07:01 PM
eltness350's Avatar
eltness350
The Untouchable
bump this would be nice to know...
Old Apr 17, 2007 | 08:34 AM
Mc556's Avatar
Mc556
Yes it would..
Old Apr 17, 2007 | 08:43 AM
Chebosto's Avatar
Chebosto
you need two resistors (2.0ohm each) plugged into the stock airbag harness location.
then you need to do the airbag reset procedure.
Old Apr 17, 2007 | 10:57 AM
Mc556's Avatar
Mc556
Thank you . The MOMO hub only came with one so I will go to radio shack in a bit. I am really not impressed with what I bought.
Old Apr 17, 2007 | 03:36 PM
05 NISMO's Avatar
05 NISMO
I also have the same problem, but when i tried to reset the airbag light it didn't work, even with the resistor installed, when i decided to put my orignal steering wheel back on, the light is still on, i cant seem to remove the light, its bugging the heck out of me, i did everything including reseting, and discounting battery for hours, and there was no luck. should i take it back to nissan and have them reset my airbag? I currently own a 2005.
Old Apr 17, 2007 | 05:14 PM
pete123's Avatar
pete123
i had the same problem, i looked every where but it is not possible. so what i did was open up the cluster real careful and just took the light bulb out of the air bag. if u dont mind just opening up the cluster then this might work. but i will tell u this, if u have an accident ur passenger air bag will not go off. the reason why passenger air bag will not go off is because u took the driver air bag out.... good luck and drive carefully
Old Apr 17, 2007 | 05:21 PM
pete123's Avatar
pete123
or u can look at this, it might also work.... https://my350z.com/forum/showthread.php?t=264018
Old Apr 17, 2007 | 08:11 PM
05 NISMO's Avatar
05 NISMO
you got by any chance know how to install the honk with the aftermarket steering wheel? pictures would be great. thanks.
Old Apr 18, 2007 | 12:10 PM
Mc556's Avatar
Mc556
That was pretty easy all you need to do is have the red wire touch a ground.
The horn button has two male plugs. One to the metal ring that came with the hub for a ground. The second attaches to the red wire. I had to cut and slice on a different plug.
Sorry no pics. Jared
Old Apr 19, 2007 | 08:20 AM
streetracer's Avatar
streetracer
get the works bell splash hub. comes with everything needed. i have it. works great.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
