do you think rear hatch struts will work for hood?
I recently upgraded my hatch struts with super strong ones. I wondering if any of you diy'ers think I can use my old oem hatch struts for the hood... with the existing old hardware.
My main concern is mounting the ball stud in the sheet metal, I wonder if the stress will bend the sheet metal?
there is a good link that uses other struts.
https://my350z.com/forum/showthread....ht=hood+struts
I wonder about the strut size.
Albert,
The stock hatch struts would be too strong to use on your hood. They are roughly double the force of what you would to need to hold your hood up. With struts that are too strong, you could end up flexing your hood too much attempting to close it. Additionally, they are about 6 inches longer than an ideal damper setup.
BTW, did you get a chance to install the new hatch struts I sent?
Originally Posted by jtabraham
Albert,
Thanks for the 411 on the damper info.
The good news is that the OEM hatch struts are such pieces of crap that in no time at all they will wear out more and not be too strong for the hood.
The bad news is that soon after that they will wear out even more, and will no longer hold the hood up. It will hit you on the head while you are working in the engine bay and kill you.
Originally Posted by THE TECH
The NRG ones are already out. How are these different Rookie?
https://my350z.com/forum/showthread....highlight=hood
My buddy was doing the changes with NRG so he has access to them.
I believe initial GB pricing will be 100 for the chromes, and 125 for the carbon fibers.
