Harness Question
Old May 16, 2007 | 07:17 AM
SunsetSunrise's Avatar
SunsetSunrise
Question Harness Question
Is it possible to install 3 or 4 point harness without installing additional hardware?
Old May 16, 2007 | 08:01 AM
Z04's Avatar
Z04
if you want it to be a true safety device, then no. otherwise you take your own life at risk if you actually try and use this improperly. the way you are desscribing would be for show use only.
Old May 16, 2007 | 09:23 AM
SunsetSunrise
Thank you.
Cant you use existing OEM belt mounting points?
The only thing is where do I mount top point of the harness?
I dont assume the rear strut bar is an option?
Old May 16, 2007 | 09:26 AM
Z04's Avatar
Z04
for the upper, you would need a properly built harness bar. check around i think there are a few people with this acutal set up on here
Old May 16, 2007 | 09:53 AM
SunsetSunrise
I have seen those.
not sure i want to ad that to my interior.
Oh well...
Thank you for the info anyway.
Old May 16, 2007 | 10:07 AM
z-u-later's Avatar
z-u-later
You can mount the harnesses to your rear strut bar.
Old Aug 22, 2007 | 05:10 PM
seekndestroy19's Avatar
seekndestroy19
how?
Old Aug 23, 2007 | 07:07 AM
THE TECH's Avatar
THE TECH
Originally Posted by seekndestroy19
how?
There are several ways which include bolting or welding.
Old Aug 23, 2007 | 08:03 AM
seekndestroy19
ide probably bolt it down if ne thing. can any1 help me out with this?
Old Aug 30, 2007 | 07:46 PM
TypeG's Avatar
TypeG
where can I get rear strut bar for 350z?
Old Aug 30, 2007 | 10:26 PM
350Z84's Avatar
350Z84
It's already built in.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
