Help w/ Nardi/Personal with Works Bell QR
Old Dec 15, 2008 | 11:10 AM
  #81
ac419's Avatar
ac419
i finally got to installing my wheel and my srs light came on with my ses light.. i reset my srs light but does anyone know how to remove the ses lights? thanks.
Old Dec 15, 2008 | 11:56 AM
  #82
Chebosto's Avatar
Chebosto
so to confirm- your check engine light came on the same time as your airbag light?
hm. shouldnt have. they're totally unrelated. if ur SLIP light comes on, thats cuz you installed your hub too far over to one side or another.
check engine light removal is either with ECU reset procedures or obd2 port clear.
maybe its something else u did...
Old Dec 15, 2008 | 12:31 PM
  #83
ac419's Avatar
ac419
hmm.. odd i only did the hub and the quick release. could it be that i've been doing my own oil changes and the dealership needs to manually reset it?
Old Dec 16, 2008 | 07:31 AM
  #84
synth19's Avatar
synth19
Check Engine light came on? That is bizarre. Pull the code and tell us what it says.
Old Dec 16, 2008 | 07:46 AM
  #85
Lawy'dU's Avatar
Lawy'dU
Originally Posted by Z1 Performance
The Personal wheels generally will need the inside edge hit with a light dremely to get the horn button to sit flush when using the quick disconnect. Not all styles do, just some. It literally takes 5 minutes to do
same with Key's racing wheels and most decent ones on the market it seems.
Old Dec 16, 2008 | 07:47 AM
  #86
Lawy'dU's Avatar
Lawy'dU
you need resistors for the air bag sensors. (sorry, i didn't take the time to read to see if you installed these)
Also, check to see if you have everything grounded properly. Most hub kits come with separate spacer type peices that act as grounds. They go before and aft of the adapter.
Old Dec 16, 2008 | 11:38 AM
  #87
ac419's Avatar
ac419
hey bro,
yeah i installed both resistors for the air bag sensors. everything was grounded properly.. i think.. i need to double check because i know i had one extra piece of metal looking spacer left over..
Old Dec 16, 2008 | 02:41 PM
  #88
Chad68's Avatar
Chad68
Bewteen my Momo wheel, quick release and bells works hub, I ended up with an extra grounding ring as well. You only need one ring.
I used mine between the wheel and quick release, which is not a good enough ground. Someday when I get off my *** I will put it between the quick release and hub where it should be.
Old Feb 25, 2009 | 07:08 PM
  #89
ac419's Avatar
ac419
hi everyone.. im removing the personal wheel and hub now. i realized when i removed the wheel i got a SLIP light as well as my TCS light. anyone know how to remove this light? thanks.
Old Jul 17, 2009 | 05:22 PM
  #90
JR350z08's Avatar
JR350z08
I'm a noob and at a complete lost on the Horn part of the install... Can anyone make a write up with pic's PLZ?... mine cam with no instructions and i think I'm missing some wires.
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
