Airbag light blinking
Old Jul 31, 2007 | 01:28 PM
Dissenter's Avatar
Dissenter
Default Airbag light blinking
Hello to all and thanks for your help!
I had a local shop replace the seat covers on my 2004 Track Model with leather after market covers. They did a great job, however, the airbag light on the dash pod is now blinking.
I checked the connections and everything seems fine. Do I need to take my Z to a dealership to have something reset? If you recall, the Track Model has the SRS Airbags in the seats.
Thanks!
Old Jul 31, 2007 | 01:36 PM
MagicPie's Avatar
MagicPie
If your going to mess around in the airbag areas, your suppose to disconnect the battery or it will give a fault code if anything is disconnected, even if the car is not turned on
The airbag module holds fault codes, and flashes the light, even if the problem no longer exist.
you can try to rest the module by disconnecting the battery over the night and see if it reset and retest, but I wouldnt count on that to work.
If your sure everything is connected, and it doesnt clear, you'll must likely have to get the dealer to reset the control module. I dont know of anyway to do it yourself
Old Jul 31, 2007 | 01:51 PM
6SPD Z33's Avatar
6SPD Z33
Originally Posted by disturbed2483
here you go it works.
1. Turn ignition switch from OFF to ON.
2. Air Bag warning lamp is on for 7 seconds and turns off, the turn ignition switch OFF within 1 second after the lamp turn off.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (Perform 3 times in total.)
5. Turn Ignition switch ON.
6. The SRS lamp has been reset it.
hope this works for you... from another site and it's been reported to work
Old Jul 31, 2007 | 01:53 PM
fast kiwi's Avatar
fast kiwi
Mine started flashing a week or two ago.. i hadnt messed with it but it was the passinger side sensor that just went faulty for what ever reson.. they overnighted the part and put it in the next day.. easy.
Old Aug 4, 2007 | 07:14 AM
Dissenter's Avatar
Dissenter
Default Fixed!
Well, I had to take the Z to a local dealership to have them reset whatever controls the airbag light.
I dropped it off at 6:30 am, they called by 8:15. All fixed and a $100 well spent! (a touch of sarcasm)
LOL!!!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
