WooOoo. Gear Indicator (MT and AT)...
http://www.nagaidenshi.co.jp/MONITOR/4500.shtml
check it out via Bablefish
i'm having my friend in japan check to see if it'll work on our CAN-based Z..
Automatic (AT) it being in car main current, "the gear has entered into some speed even with AT, you saw to be", answering the demand that "we want the indicator like the race/lace car by the MT car", new sale ultra shift indicator NO.4500.
With the product which was developed as apex of the typical digital product of ultra indicating gear position in large-sized red LED in real time, it designates sport driving as more pleasant ones.
Shift indicator No.4500
Blue LED standard model
No.4500-10
Blue LED carbon model
No.4500-50
You whispered from beginning of shift indicator sale, "existence of the blue LED model" was, but finally meeting expectation at last, new it sells the new model blue model 2 type. It was used in the up-to-date vehicle dashboard. Acting in concert to blue type illumination, it developed the new model shift indicator which adopts the blue LED which matches best. Furthermore the standard BASIC model and, from the Spartan setting 2 types of carbon look specification to the LED ring cover.
While tightening from the cockpit of the car more, vivid blue indication furthermore raised visibility.
It becomes the same specification as standard item No.4500 note) regarding the functional aspect.
Main function of shiftindicator No.4500 type
*Gear position real time indication
With individual operational system, gear position is indicated in the large-sized red LED indicator in real time.
Indicating gear position in real time of course even by the AT car. In the D range it is shifted to some speed, in comparison with the manual car as the function which by very the AT car which it is difficult to distinguish is required, in sport driving by the AT car it is the item which cannot be missed.
*Shift change indicator display function
We inform inside the range of the torque territory which is optimum to engine quality by maximum rpm at the time of down-shift and the smallest rpm at the time of shift rise each setting, about the optimum shift change timing shift with the change indication of UP/DOWN. In the MT car as guide "to of the heel and" in sport travelling e.g., it utilizes the power is shown as the function which cannot be missed.
*Reverse display function
It can verify easily the distinction present with the complicated shift pattern form which is seen mainly in MT car such as import car difficult driving reverse gear position, reverse of the indicator (the gear) by indication, the shift mistake when going backwards beforehand prevents.
*Lockup indicator (in portion of AT car correspondence)
In the AT car it can verify the lockup at the high-speed travelling time and the like by the illumination of the lockup indicator, this more low fuel economy travelling (the economy run) becomes possible in standard.
*Simple installation
I G power source (even with ACC power source yes), body ground, vehicle speed signal, rotary signal and reverse signal (mainly only MT car) simple installation just of connection of 5 places. Of course detailed setting method and method of installation, diagram of the vehicle speed signal every of each model it has belonged in the product.
* Main specification of 4500 types
* No.4500 basic diagram
- 12 V minus ground exclusive use
- Guaranteeing instantaneous visibility by large-sized red LED indication
- Shift position display function (to maximum of 9 speeds setting possibility)
- AT car lockup display function (in part model indicatory possibility)
- Shift change indicator function
- Conformity model: It conforms to the most domestic car and the import car not just AT and MT. (The part CVT car you exclude) however, the digital vehicle speed signal and the rotary signal are needed
- Long-term product guarantee of 1 year: Product guarantee other ultra product similar 1 years.
* External size (unit =mm)
* Note
- This product is the gasoline engine vehicle exclusive use of 12V minus the ground.
- The vehicle speed signal is necessary in the installation of this product. Being genuine, combined use of another sale speed sensor No.6680 is necessary in the model which is not equipment of the vehicle speed signal.
- The engine rpm signal is necessary in the installation of this product. The model which the engine rpm signal cannot be taken (the earl amplifier conformity chart) combined use of another sale earl amplifier No.4990 is necessary.
- Vehicle speed signal of digital signal
You can use by 2, 4 and 8 pulse cars. NISSAN Y32 (CEDRIC, the installation wound it is not possible) to 16 pulse cars such as Grolier and seaming machine. Concerning the import car because already part is the operation verification being completed, please inquire the details to the import car to our company business.
* About the vehicle speed signal
Our company shift indicator corresponds to only the digital signal.
The rough sketch verification in reference.
"Digital signal ripple mark (rectangular wave)": Correspondence
The number of pulses: It corresponds to 8 pulses
Concerning many multi pulses in the import car our company No.4995 S S C. by the fact that it jointly uses corresponding possibility
"Analog signal ripple mark (interchange ripple mark)": Our company No.4995 S S C. by the fact that it jointly uses corresponding possibility
- The Diesel car or engine rpm (REV) you cannot install to the vehicle which cannot detect the signal.
* About the engine rpm signal
Our company indicator corresponds to the negative signal of the digital signal or the IG coil.
- It is installing possible, regardless of the MT car and the AT car but the fixed mode of CVT (sport mode and the like) in the model which is not being not to be able to install note.
* Point of caution of AT car shift indication
In the AT car where it can use the general torque converter it meaning that oil control has intervened, there are times when gear position with respect to fact compared to is indicated at the time of accelerator OFF.
For the second time, if the accelerator was depressed, the actual gear position which was studied is indicated. Above after understanding before the purchasing, please purchase shift indicator No.4500.
- Option 4010/4500 joint harness No.4509-10 ¥1,890 (tax 込)
* Main function of option4010/4500 joint harness(selling separately)
* Basic installation figure
As for this joint harness speed monitor No. 4010 systems and shift indicator No. 4500 simultaneously it is the one-touch harness kit which is made connection possible.
Presently our company speed monitors (No.4010 4020 4015 4016) the car which already becomes installation, or the joint harness which very can be installed in convenience on the person who thinks of installing simultaneously was sold.
- Installing time reduces by half by the fact that the external harness is standardized.
- We can install also wiring of the eye which was seen smartly.
* Note
- As for this product speed monitor system (No. 4010, 4015, 4016 and 4020) product and shift indicator No. Because of the harness kit in order to connect 4500 systems you cannot use for other use. (You cannot use for No.4000 、 4060/4065)
- With joint harness installing the case where limiter cutting job of speed monitor system is done sufficiently note in wiring and the like.
- 2 steps or more piling up the joint harness, please do not use. There are times when vehicle speed and the rotary signal become unable to grasp.
No.4500-10
No.4500-50
* Note
* Note
I noticed in the new 350Z HyperRev magazine that the 07 models have a gear indicator in the RPM guage. Now I don't know if that's in Japan only and I don't know if it's for a manual or automatic....
i got a few emails back and forth.
Racing Beat is their US distributors. but they dont have any clue if it'll work on the Z.. i guess i'll have to wait for my friend in japan to report back. maybe they have better luck.
edit:
the owner of Nagai Electronics is emailing me now..
he says it work in Japanese spec Z33 with their RPM adapter... so i asked if they'd be willing to sell it to USA spec since they dont' know it it'll work.
ill let you know when they reply back. he's pretty prompt in his replies.
edit:
OHH kayyy.
after about a month of back n forth emails with Nagai Electronics and their US distributors (Tomei USA)
we're about to embark on some tests to see feesibility of the unit on the US-spec Z33 and possibly other cars. (I have an S14 with a KA-T to test on as well as some other cars at my disposal)
Things are looking good. i have the unit in hand along with the RPM signal adapter.. more updates soon. we also are tasked to do the Japanese->English translation.. that'll be fun!
Bodyboarder81
Sep 21, 2015 06:23 AM
hardwood66
Sep 8, 2015 04:31 AM
