Annoying squeaking rattling noise
Old Aug 24, 2007 | 04:56 PM
philvpt's Avatar
philvpt
Default Annoying squeaking rattling noise
Hello new to this 350Z site. I own a 2003 Performance model 350Z. About 4-6 months ago my window or door starting making this squeaky rattly noise - comes and goes and you can hear it going over bumps etc. Its like chinese water torture!
The last time I took my car in to be serviced by Nissan I asked them to see if they could resolve the matter. As expected, their response was "dahhh we took it for a test drive and could not hear anything. Cars these days have lots of plastic parts in high heat they can start making noise."
Has anyone experienced a similar situation ? Any advisable resolutions ? If I can't get rid of this noise I am going to get rid of the car !
Thanks for any help !
Old Aug 25, 2007 | 01:44 PM
kwakster928's Avatar
kwakster928
Hey,
I dont know whether you have the same problem I had but I had this metal sounding rattle coming from the passenger side. I found out that it was coming from the passenger side dash where glove compartment sits in other normal cars. The rattle came from a metal casing that covers the passenger side airbag. It is easily accessible with couple flat screw drivers. If you think the sound is coming from there, I will try to write up a DIY for you.
Old Aug 25, 2007 | 01:50 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
SEARCH. We covered this about 4 years ago. When we all had 2003 Z's.
Old Aug 26, 2007 | 01:21 AM
350zrn35's Avatar
350zrn35
was your window closed / half opened?
Old Aug 26, 2007 | 02:51 AM
philvpt's Avatar
philvpt
Default squeak noise
My window can be closed and opened - it does not matter. This problem seems to have progressed and now it seems worse with the window open. Was considering taking the door off and apart but don't know how.
Old Aug 26, 2007 | 02:54 AM
philvpt's Avatar
philvpt
Default Squeak noise
I will check the glove box but don't think this is it sound def is coming from driver's side door.
I may be soon among the had a 2003 Z club !!
Thanks for your input !
Old Aug 26, 2007 | 06:01 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
2003 had the most issues Check your front tires often for uneven wear.
Old Aug 26, 2007 | 11:38 AM
philvpt's Avatar
philvpt
Default Squeak sound
Thanks can you write me up a DIY on the front passenger side air bag bracket ?
Had a recall on the front tires due to toe in. Nissan adjusted the toe in and replaced the front tires due to excess tire roar and uneven tread wear. ZERO problems ever since. Running a sweet set of sticky Dunlops right now, very quiet no uneven wear.
Old Oct 3, 2007 | 06:21 PM
tivaj's Avatar
tivaj
Originally Posted by kwakster928
Hey,
Can you please post the DIY. I have the same rattle
Old Oct 5, 2007 | 05:40 AM
kobalt's Avatar
kobalt
^ DIY would be nice. By what I read here I'm pretty sure that is my problem, except I have an 05...
Old Dec 6, 2007 | 10:51 AM
RedBullRR's Avatar
RedBullRR
NO DIY huh?! Dam I have the same freakin rattle in my 04.5
Old Dec 6, 2007 | 11:00 AM
cheshirecat79's Avatar
cheshirecat79
Here's a how-to on taking the door apart. I would suggest doing this to check for rattles. If you want, with the door apart, turn your car on and rev it a little to see if you can get some vibration going enough to better localize where the sound is coming from inside the door (if that is where it actually is). Either way, you should have a better idea where the sound is exactly coming from after doing this.
http://liljerk.morpheus.net/350Z/front_speakers/
Old Dec 6, 2007 | 11:14 AM
350Zenophile's Avatar
350Zenophile
Hey,
Hey yeah, do that please...I think that is where my main rattle is coming from.
Old Dec 6, 2007 | 02:31 PM
trains1937's Avatar
trains1937
Take it back to Nissan service and go out in the car with them when they test drive it. Point out the squeaking sound and make sure they hear what you hear.
Old Dec 6, 2007 | 08:44 PM
DaProdigy's Avatar
DaProdigy
i have the same problem drives me nuts i thought it was my speakers i put in... it's a squeeky noise coming from the passenger side
Old Jan 2, 2008 | 06:18 AM
RedBullRR's Avatar
RedBullRR
Any update on that DIY?
Old Jan 8, 2008 | 05:50 AM
RedBullRR's Avatar
RedBullRR
Bump
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
