Steering Wheel Install DIY?
Old Sep 1, 2007 | 08:18 PM
jining's Avatar
jining
Default Steering Wheel Install DIY?
Just curious if there is a DIY for installing a steering wheel and quick release hub.
Thanks in advance.
-Aaron
Old Sep 1, 2007 | 08:50 PM
Shift_Z33's Avatar
Shift_Z33
Im pretty sure you just:
-Disconnect battery
-take screws out of the side of the wheel that hold the airbag in
-unplug airbag/remove airbag
-break loose the big nut holding the wheel on and then remove it
Old Sep 1, 2007 | 08:51 PM
jining's Avatar
jining
Hmm sounds easy enough.. your sig made me try and squash the bug...
Old Sep 1, 2007 | 08:52 PM
Shift_Z33's Avatar
Shift_Z33
I also think the airbag srews are actually torx bolts.
Jay'Z's Avatar
Jay'Z
Its that easy.. lol
Old Sep 1, 2007 | 08:54 PM
jining's Avatar
jining
is it really pretty easy or you just being sarcastic Jay'z ? Yea they are torx bolts
Old Sep 2, 2007 | 02:02 AM
ChinaClipper's Avatar
ChinaClipper
Specifically, they are "tamper proof 34T torx bolts". Unless you buy the specific bit to un-do these bolts, an ordinary 34T bit will not have the nipple recess in the end. When I took my steering wheel off to recover it in custom leather, I replaced the torx bolts with ordinary hex head M6 bolts to reinstall the steering wheel.
HTH,
ChinaClipper
Old Sep 2, 2007 | 02:56 AM
TayTaythatsme04's Avatar
TayTaythatsme04
its a pretty easy DIY, only the part thats tough is the torx bolts. And yes you need the special tool or you cant even get the stock wheel off
T
Old Sep 2, 2007 | 12:53 PM
jining's Avatar
jining
where might I find the bit for the torx bolts?
Old Sep 2, 2007 | 12:59 PM
SuperBlack350z's Avatar
SuperBlack350z
you can find quality ones at sears. Also, i used a steering wheel puller to take it off.
Old Sep 2, 2007 | 01:00 PM
jining's Avatar
jining
Do you think a steering wheel puller is necessary or can you get it off with brute force
Old Sep 2, 2007 | 01:02 PM
SuperBlack350z
Not sure. I never taken any steering wheels off without a steeringi wheel puller. It's much easier and i have one here at home so i never had that option. I'm guessing it can be done but i rather do it the right way. I think you can borrow one at some auto parts stores.
Old Sep 2, 2007 | 01:04 PM
jining's Avatar
jining
Ah ok I suppose I will just rent one
Old Sep 2, 2007 | 03:21 PM
ChinaClipper
I bought mine at Ace Hardware. Just make sure you buy a tamper proof 34T bit instead of a standard, 34T bit. I also found in my case, that the steering wheel puller was unnecessary. After nut removal (19mm socket), a sharp tug freed the wheel from the splines.
HTH,
ChinaClipper
Old Sep 2, 2007 | 05:45 PM
jining's Avatar
jining
cool thanks
Old Sep 2, 2007 | 06:45 PM
drsifu's Avatar
drsifu
hmmm....i think it is a T30 tamper proof torx bolt
recently installed one myself.
it is included if you purchase the Works Bell short hub.
other tool you need is a 19 mm deep socket (i believe it is 19mm)
good luck
Old Sep 2, 2007 | 06:46 PM
jining's Avatar
jining
cool just ordered the works bell short hub
Old Sep 2, 2007 | 06:48 PM
drsifu's Avatar
drsifu
https://my350z.com/forum/exterior-and-interior/286602-help-w-nardi-personal-with-works-bell-qr.html
my experience installing an aftermarket steering wheel
Old Sep 3, 2007 | 05:33 AM
ChinaClipper
good luck
Correction on my previous advise - drsifu is right, the torx size is 30T and NOT 34T. Thx for the catch!
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
