installing oem spoiler using tape
Old Nov 21, 2007 | 11:03 AM
AugustXII's Avatar
AugustXII
Default installing oem spoiler using tape
would it be ok to install the oem spoiler using car tape? i'm scared it might fly off while i'm on the freeway
Old Nov 21, 2007 | 11:09 AM
VO...'s Avatar
VO...
Administrator
Old Nov 21, 2007 | 11:21 AM
tanman350z's Avatar
tanman350z
If its a true fit OEM spoiler you will have 2 screws holes. Drill out the hatch after you've measured and marked the holes and fasten spoiler to hatch with screws, after applying double sided tape. Dont forget to put some type of primer or rust inhibitor to holes.
Old Nov 21, 2007 | 12:15 PM
AugustXII's Avatar
AugustXII
hahah so i HAVE to drill holes in it.....ok, now is it really easy to do? or should i just take it to the dealer
Old Nov 21, 2007 | 12:51 PM
vnarang's Avatar
vnarang
i wouldnt take it to the dealer, but id take it to someone who knows what theyre doing. like a local car body shop
Old Nov 21, 2007 | 12:55 PM
reserved's Avatar
reserved
you do NOT have to use screws - just use the tape
Old Nov 21, 2007 | 01:24 PM
meaj82's Avatar
meaj82
+1
My seibon tb is held on only w/ double sided and I'm always on the freeway daily.
Old Nov 21, 2007 | 01:32 PM
Chebosto's Avatar
Chebosto
3m industrial all weather double stick tape. (grey one)
Old Nov 21, 2007 | 01:34 PM
Nexx's Avatar
Nexx
+1, that **** is strong. will have zero problems keeping that small spoiler on the hatch under all conditions. taking it off on the other will be a biatch.
Old Nov 21, 2007 | 09:34 PM
AugustXII's Avatar
AugustXII
ahhh ok thanks guys!
Old Nov 21, 2007 | 11:14 PM
gsazabi's Avatar
gsazabi
Like Cheston said if you use 3M tape it'll be fine.
If it can hold my Blitz then it can hold the OEM spoiler.
Old Nov 22, 2007 | 07:28 PM
fabien350z's Avatar
fabien350z
same thing for me : Blitz rear spoiler and ONLY 3M tape
I'm every days on freeway and no problem (even at 250km/h -german- freeways)
350z82
Oct 1, 2015 06:25 PM
