LED lighting help
Old Dec 22, 2007 | 06:05 PM
aleicgrant's Avatar
aleicgrant
Default LED lighting help
I have a halo kit for the Z emblem. I would like to wire it so it comes on with the running light but also blinks with the blinker. Possible with relays? if so can someone help me with wiring. Currently wired into the parking lights
thanks for your help
Old Dec 23, 2007 | 08:16 AM
ZKansasZ's Avatar
ZKansasZ
the two wire come out from your halo, do 1 to the possitive parking light, the other one connect to possitive of your turn signal bulbs. It should work!
POST SOME PICTURES, damn it! lol
I did not do this mod on my z but I did the same set up on my 02 accord AND my wife 06 RSX. But its a general technique so it should work on your z.
Good luck!
Old Dec 23, 2007 | 08:22 AM
aleicgrant's Avatar
aleicgrant
the halo has two wires, one red, one black. Are you saying I should tap off a line from the positive thats connected to the parking lights and run it to the positive of the blinker?
Old Dec 23, 2007 | 08:30 AM
Exiled Lakai's Avatar
Exiled Lakai
Good luck!
really? so does it use the other bulb for its grounding? How does get a ground when both positives are getting juice. i.e. city lights on and blinker light going?
Old Dec 23, 2007 | 08:33 AM
aleicgrant's Avatar
aleicgrant
yeah I am confused on this one. Would think you would need some sort of relay
Old Dec 23, 2007 | 08:34 AM
ZKansasZ's Avatar
ZKansasZ
you wanted the halo to stay ON and FLASH with turn signal, too, right? Then you dont need ground! trust me!
Old Dec 24, 2007 | 09:42 AM
ZKansasZ's Avatar
ZKansasZ
Any update on this?
oh and pictures are needed, hehehe
Old Dec 24, 2007 | 10:08 AM
aleicgrant's Avatar
aleicgrant
going to do it after xmas. So I have it straight, halo red wire to blinker (green) then tap off the red wire to the parking light (green) what do I do with the black ground wire?
Old Dec 24, 2007 | 10:18 AM
ZKansasZ's Avatar
ZKansasZ
no, u hook up the red wire to the green of your parking light
Then you hook the black wire from your halo to your whatever color of positive wire of your blinker.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
