06 headlights in a 05 base
Old Jan 1, 2008 | 09:25 PM
NewZ84's Avatar
NewZ84
Default 06 headlights in a 05 base
searched but can't find a straight answer. will 06/07 headlights work in an 05 base without modification? plug n play ?? or what needs to be modified ?
Old Jan 1, 2008 | 09:49 PM
gsazabi's Avatar
gsazabi
Plug-n-play
Old Jan 1, 2008 | 10:33 PM
VisionaryRacing's Avatar
VisionaryRacing
I do not believe they will work since the base models did not come with HID's. I maybe wrong, however I am 99.9% sure I am right.
Old Jan 1, 2008 | 10:45 PM
MrWatchDawg's Avatar
MrWatchDawg
with base i doubt they will work because the ball in side might have issues because the beam is being "shot" thru versus with the base having a standard bulb
but thats just my 2 cents
-mo
Old Jan 1, 2008 | 10:49 PM
jimmyloose's Avatar
jimmyloose
Take your headlight off. If you have a plug with 8 connectors, it should plug straight in. If you have 6 connectors, PM me and I can build you a harness.
Old Jan 1, 2008 | 10:50 PM
jimmyloose's Avatar
jimmyloose
-mo
I don't know which wrong to respond to.
Old Jan 1, 2008 | 10:58 PM
VisionaryRacing
Reading over some stuff, I am again pretty sure it will not work
Old Jan 1, 2008 | 11:39 PM
MyFairladyZ2006's Avatar
MyFairladyZ2006
Yea you need HID's too
Old Jan 2, 2008 | 07:09 AM
NewZ84's Avatar
NewZ84
alright, i'm completely confused now. what if i take the complete headlight assembly from an 6 and attempt to install it on my base 05? i'm new to HID....if i got 06 headlights, why would i need HIDs...i don't get it?
Old Jan 2, 2008 | 01:20 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
It will work on a Base, you just need to hard wire everything.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
