brake light randomly turning on and other random stuff
Old Jan 20, 2008 | 01:53 PM
MrWatchDawg's Avatar
MrWatchDawg
Default brake light randomly turning on and other random stuff
i have a 05 roadster and I am having some issues with it. its still under warranty but i wanted to ask you.
my windows randomly roll down and sometimes dont go up, but if i hit the driver side door they do work again. I know its the motor BUT i took into the dealership and they were like we cant do anything about this, we cant replicate the problem but it happens all the time to me.
second problem is that lately i have noticed (i have a auto tranny) when i am in tip tronic mode, i will be driving and when i shift, randomly my break light will turn on, the light that shows that my hand brake is up? Anyone ever experience that issue?
what should i do in this instance?
-Mo
Old Jan 20, 2008 | 03:02 PM
bailey bill's Avatar
bailey bill
-Mo
The BRAKE light actually has 2 functions. 1) It tells you that teh Park brake lever is pulled, and 2) it tells you if the brake fluid reservoiir is low.
bill
Old Jan 20, 2008 | 03:14 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
check the fluid as stated above.
Old Jan 20, 2008 | 03:17 PM
Clipdin's Avatar
Clipdin
SHIFT_happens
bill
Or 3) your car is posessed!!
Old Jan 20, 2008 | 03:19 PM
CANNOT DUPLICATE
That must teach that at Nissan service school.
Old Jan 20, 2008 | 04:29 PM
MrWatchDawg
im ****ing pissed
the only dealership thats good in the area is like 40 miles away one way
-Mo
Old Jan 20, 2008 | 04:40 PM
ANXIOUZ's Avatar
ANXIOUZ
The window motors are crap and is a common item to fail. Sounds like you need both fixed.
Old Jan 20, 2008 | 04:42 PM
Jay'Z's Avatar
Jay'Z
Yep.. Window motors are randomly needing replacement......
Old Jan 20, 2008 | 06:51 PM
MrWatchDawg
now how can theree asses fix it
-MO
Old Jan 20, 2008 | 07:59 PM
roast's Avatar
roast
The brake light means your fluid is low. You can add more fluid, but your pads are probably getting worn and will probably need replaced (along with turning or replacing the rotors). It would be advisable to check the pads & rotors before adding fluid.
Old Jan 21, 2008 | 07:41 AM
ANXIOUZ's Avatar
ANXIOUZ
-MO
Am I mistaken that we're all using the same internet right now?
http://www.myzroadster.no-ip.org/Fil.../NTB04-089.htm
http://x.nissanhelp.com/forums/Knowl...pp=10&keyid=46
The source of all: http://www.nissanhelp.com
Old Jan 21, 2008 | 08:56 AM
MrWatchDawg
but do u actaully think it needs to be reset?
and also i am getting my break pads, rotors, and lines replaces. doing the stop tech stage 2 upgrade! so hopefully that fixed my problem
-Mo
Old Jan 21, 2008 | 09:08 AM
ANXIOUZ's Avatar
ANXIOUZ
Yes, I think it just needs to be reset. I'm not actually sure I've heard of anyone getting the motor physically replaced...the Nissan techs always seem to just reset them to fix any problems. If you're having any issues with the motor (windows not rolling up, only going halfway up/down, etc.) the motor reset always seems to fix it. If you're still under warranty, it's covered there. If not, maybe you can sweet talk them.
Old Jan 21, 2008 | 09:13 AM
MrWatchDawg
ill reset it on my own and see how that goes than
-mo
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
