1. Pop your trunk
2. you will see three plastic caps on each tail lights that has to be pulled out. Use a flat head screwdriver and just pop them straight off.
3. you will see a 10mm bolt underneat those plastic caps. Take all three of them off each tail light.
4. Pull the tail light off.
5. Twist off whatever bulb you need to replace
