headlights question
Old Apr 2, 2008 | 06:51 PM
BojanC350z's Avatar
BojanC350z
Default headlights question
my headlights dont have that clean look to them...they look like they are sort of foggy from then inside and there is no way i can clean them.. it doesnt look good at all and im sure it reduces some visibility because of that. i went to nissan asked them to change them but they refused they said its not under warrenty, they said they will only replace if they are damaged? i heard by z owneers it is under warrenty thats the only info i have on this i searchd but couldnt find anything. am i wrong or is the dealership trying to get out of it?
Old Apr 2, 2008 | 08:57 PM
Built2shredZ's Avatar
Built2shredZ
Its oxidation on top of the plastic headlight case, you can get rid of it with a polish but it will come back 3-4 weeks later, so it will be a on going process... My 2003 G35 was really bad and my 2006 FX35 after only 8 months had the same problem, luckily for me they had a recall on the FX35 headlights so I got new ones....
Old Apr 2, 2008 | 09:28 PM
350ZTheStandard's Avatar
350ZTheStandard
Have the headlights covered with 3M clear bra material, costs about $75.00 depending on the local installer. No more problems, also help out if you get a stone to the headlights..
Old Apr 2, 2008 | 09:41 PM
SteevoZ's Avatar
SteevoZ
If it is oxidation and its on the outside, I had the same and i got it all off by high speed buffing it with 3m rubbing compound. Did this about 2 months ago and the lights have been spotless ever since.
Old Apr 3, 2008 | 09:24 AM
Velocity350Z's Avatar
Velocity350Z
+1 This is a good way to protect your headlights.
Old Apr 3, 2008 | 08:25 PM
ladyzed's Avatar
ladyzed
I polished mine with a Blue Bird Pneumatic polisher (100psi+wool) and 2000 grit liquid compound. Again, I am a highly experienced (not to brag or anything) detailer, so I don't recommend doing this because you'll burn right throug the plastic within seconds.
Mine have been clear for a few months now. Nothing came back
Old Apr 4, 2008 | 08:49 AM
Lento's Avatar
Lento
Happened to my RSX. If your car suffers extream weather changes (New England weather) it causes the sealant to crack and let in air. The condensation builds up inside.
I took my RSX to the Acura dealership and they fixed it for free. I wish Nissan was run more like Acura.
Old Apr 4, 2008 | 12:59 PM
hugoboss's Avatar
hugoboss
my headlights have the same problem. where can i take my z to get the headlights polished with m3?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
