Need help installing Takata Harness!!!!
Old May 13, 2008 | 11:40 AM
chris'smax's Avatar
chris'smax
Default Need help installing Takata Harness!!!!
Ok i am installing a takata harness right now and i want to mount the shoulder straps on the rear strut brace. For those of you who have used this as a mounting point how have you gone about doing this? I would prefer not to do any welding due to the danger of messing up my interior. Right Now i have the holes drilled into the rear strut brace (used a 3/8" bit) and at lunch i bought some taps in order to tap the holes (got a 9mm and a 10mm). Now after looking at the holes the metal apears to be about 1/8" thick maybe. I don't think this leaves enough thread for the eyebolts so i am thinking of putting a nutt on the other side. Any thoughts?
PS i have a cusco roll cage so please don't give me the roll over danger shpeel
Old May 13, 2008 | 11:44 AM
soleil's Avatar
soleil
NolaZcc
i hate u
Old May 13, 2008 | 11:51 AM
chris'smax's Avatar
chris'smax
Originally Posted by soleil350z
i hate u
why
Old May 13, 2008 | 12:00 PM
Mazinger Z's Avatar
Mazinger Z
Originally Posted by chris'smax
why
Because you have a Cusco rollcage and takata harnesses. I hate u too.
Old May 13, 2008 | 12:02 PM
soleil's Avatar
soleil
NolaZcc
and re30's, project mu brakes and twins....but i aint mad at ya....i want to see pics of the new look man
Old May 13, 2008 | 12:04 PM
teh215's Avatar
teh215
I would think that using a nut and bolt would work. I would suggest that you use large washers on the front and back of the metal to help prevent pullout. Also, the bolt should probably be perpendicular to the strap to further reduce the chance of pullout. Just my 2¢ and I an NOT an engineer but, that would be how I would approach it in the abscence of any real knowledge of the subject.
Old May 13, 2008 | 12:12 PM
chris'smax's Avatar
chris'smax
haters in the house????? . Hopefully i can get some pics before i leave and go throwing my car off the side of a mountain at zdayz
Old May 13, 2008 | 12:13 PM
groovin_350z's Avatar
groovin_350z
Sleeps in 350Z
i went to home depot and found eye bolts and basically added a nut on the opposite side like what u wrote above.
old pic but this is all i got right now
Old May 13, 2008 | 12:15 PM
blasian's Avatar
blasian
I'm lower than you! Ooooooooo what now bish
Old May 13, 2008 | 12:16 PM
chris'smax's Avatar
chris'smax
Thanks for the suggestions. I plan on using lock washers and a flat washer on the backside. I was thinking parallel would be better since there would be less chance of sheering force, but hell i am no engineering major either. Just a lowly construction mgmt major
Old May 13, 2008 | 12:17 PM
chris'smax's Avatar
chris'smax
Cool. I was just messing around and picked up a old open ended lug nut and the damn thing fit perfectly. I found my nutts!
Old May 13, 2008 | 12:20 PM
soleil's Avatar
soleil
NolaZcc
i got dibs on the twins if it makes it through...pics or ban.....
Old May 13, 2008 | 12:21 PM
groovin_350z
Sleeps in 350Z
funny how u mentioned that. ive done that before as well. ahhaha
Old May 13, 2008 | 12:30 PM
teh215's Avatar
teh215
I guess that would work but, I would use at least a 3" washer. IIRC that metal is fairly thin back there. As far a sheer vs. pullout, my guess would be that a bolt is more resistant to sheer forces since that is how the factory bolts are anchored. We need an engineer in this thread.
Old May 13, 2008 | 01:31 PM
groovin_350z
Sleeps in 350Z
ill check what size washer i used back there later. its been a long time since the time i had that installed.
Old May 13, 2008 | 05:25 PM
yusoslo's Avatar
yusoslo
that pictured method does not look safe!!!!!!!!!!!!!!!!!!!!
I am an engineer and I would not have that mounted like that. I would have 2 seperate areas with a welded reinforcement plate on it.
Or....buy a sparco harness bar
Old May 13, 2008 | 06:46 PM
OPTIMO's Avatar
OPTIMO
That won't pass tech.
Roll cage? I hope that's primarily a track car, not a street car. If memory serves correctly, the Cusco isn't an SCCA approved design anyway, but I could be mistaken.
I actually think with all the money you've spent, you've successfully made the car LESS safe.
Old May 13, 2008 | 08:43 PM
Mazinger Z's Avatar
Mazinger Z
LOL... I was thinking... is that really going to work? Maybe add an extra metal plate behind the bolt?
Old May 14, 2008 | 03:23 PM
chris'smax's Avatar
chris'smax
going to get the rollcage welded later on . I got the harness installed and i used a 3 inch washer on the backside. My dad is a mechanical engineer and i got his approval for what its worth
HoBrahYouStink
Jun 24, 2016 10:58 PM
