Seibon TS CF Hood fitment (pictures)
Old Jul 1, 2008 | 04:54 PM
wannabuy350z's Avatar
wannabuy350z
Default Seibon TS CF Hood fitment (pictures)
I purchase this hood just days ago, and installed it.
I want to say its the worst fitment ever.
the gap between the hood and the fender is perfect. the rear lining is perfect.
my issue is the mid of the hood going forward to the bumper. its like almost an inch to high.
I have lowered my hood latch(lock), same thing and its ever harder for it to catch the lock.
Help
Old Jul 1, 2008 | 05:02 PM
stein's Avatar
stein
Oh my, there has to be a way to bring that down!
Old Jul 1, 2008 | 05:13 PM
wannabuy350z
when my stock hood was on, it would be slightly lifted on the drivers side due to the JWT intake filter for the TT kit.
Old Jul 1, 2008 | 05:42 PM
turismo's Avatar
turismo
I wouldnt drive it like that if I where you. If you do, you better have some hood pins
Old Jul 1, 2008 | 05:43 PM
SpoilsofWar's Avatar
SpoilsofWar
lol, +1... That could get real ugly real quick.
Old Jul 1, 2008 | 05:53 PM
wannabuy350z
its not like it isnt secure, just has a gap!
I have already driven it like this since the day i got it.
Old Jul 1, 2008 | 05:54 PM
415mm's Avatar
415mm
Professional
Is this the 07 ts hood? if its the 03-06 seibon cf ts hood than that fitment issue has been an issue to people before. on my buddy's ts hood you can see the inside of his engine bay if you tried. didn't stop me from buying one though and mine fits much better. luck of the draw i guess.
Old Jul 1, 2008 | 05:56 PM
Nexx's Avatar
Nexx
doesnt matter how secure it is the latch hook on the carbon fiber hoods are weakly attached. get any good mount of air under that hood and its has a decent chance of flying open while you are driving, causing your windshield and roof to get pwned. thats thousands of dollars of damage not mention how dangerous it is to the driver.
Old Jul 1, 2008 | 06:02 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
get hood pins and shim the back of the hood.
Old Jul 1, 2008 | 06:10 PM
turismo's Avatar
turismo
+1
Old Jul 1, 2008 | 06:27 PM
Chad68's Avatar
Chad68
Try removing the battery cover and the cover on the other side and the strut bar. See if that helps.
Old Jul 1, 2008 | 11:02 PM
wannabuy350z
^ i'll do that. even thought it closes the battery cover and brake oil cover will space to spare, it might be the strut bar.
maybe I should put some powder in the inner of the hood and try closing it, and lift it back up, and I will see where the marks were.
Old Jul 2, 2008 | 12:22 AM
A.H's Avatar
A.H
So this is the replica of the Top Secret Hood? The real TS has excellent fitment correct?
Old Jul 2, 2008 | 12:28 AM
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
with a little more adjustment im pretty sure it could look better try bringing the hood towards the nose of the car more.
hows it sitting near the dash? good or kinda off there as well?
Old Jul 2, 2008 | 04:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
very common issue unfortunately. Some fit better than others, and it's been like that since the day the first of these hoods came out.
Z1 Performance
Former Sponsor
This is not a top secret replica...they just call it "TS".
Yes, Top Secret parts have excellent fit and finish
Old Jul 2, 2008 | 08:30 AM
wannabuy350z
its near perfect close to the dash, but I guess I can pull it towards the nose and see what happens
Old Jul 2, 2008 | 11:51 AM
ZTEALTH's Avatar
ZTEALTH
sometimes when a composite hood is laying flat (at the warehouse), it will want to flatten out. especially when its warm weather. after all, it's just plastic!
Old Jul 2, 2008 | 12:24 PM
Kal_El's Avatar
Kal_El
I just installed the 07+ TS hood and when we first installed it it wouldn't seem to go all the way down. When you push down on it does it go down further and just not latch completely down (lock)? Or is there resistance like it is pressing against something? We played with the latch a little bit, but in the end we had to let it down slowly until it catches on the latch then press down very firmly and it latches completely. Other than that the fitment is perfect.
Before I got the hood I didn't realize the problem with the OEM latch failing. I hate hood pins but will probably invest in them just in case....
Old Jul 2, 2008 | 03:38 PM
Z PHAT Z's Avatar
Z PHAT Z
I got the same hood and same issue. I modified my battery and fluid covers to sit lower so the vents of the hood don't hit the covers. People that have this hood have to be careful when closing it. You can't drop it down to close it and latch. You have to let it sit down then use both hands to press it at the edge to latch it. If not carefully, it will developed crack across the hood.
