Tint
Old Aug 12, 2008 | 05:59 PM
McGuckin's Avatar
McGuckin
Default Tint
I recently got my winows tinted and a few days later I noticed the corner of the drivers side window peeling near the mirror. I think this is due to the window rolling down when the door opens. Has anyone else had this issue? My tint guy is gonna retint for me but I dont want the same issue. Any suggestions?
Old Aug 13, 2008 | 06:54 AM
timmays350's Avatar
timmays350
usually that only happens if you roll your windows down without letting the window fully dry, which usually only takes at the most a couple days, but they recommend not rolling the windows down for a week to be on the safe side. either that or he didn't get all the way into the corner with his squeegee. either way it's good he's redoing it for you, cause it doesn't take long for the whole piece of film to end up inside your door.
Old Aug 13, 2008 | 07:15 AM
eze-edsel's Avatar
eze-edsel
Dont roll your windows down for a week after getting it tinted.
Old Aug 13, 2008 | 07:31 AM
OldDirty Z33's Avatar
OldDirty Z33
Same here I just ignore mine. To lazy to get it fixed. BTW the real way is to take your window fuse out when new tint is installed so the windows don't roll down when you open your door.
Old Aug 13, 2008 | 07:39 AM
jwillard0201's Avatar
jwillard0201
the guy who did mine used a heat gun to dry it faster, since the windows raise/lower when you open/close the door. Never had a problem with peeling off
Old Aug 13, 2008 | 07:46 AM
eze-edsel's Avatar
eze-edsel
that will cause the window to hit the car, and maybe crack or bust the window.
+1 on the heat gun idea. You can buy them cheap at Sears.
Old Aug 13, 2008 | 07:49 AM
OldDirty Z33
Na it wont. I did it for a week you just barely roll the window down before you take the fuse out. Mabye I_I that much haha.
Old Aug 13, 2008 | 08:24 AM
jgregory124's Avatar
jgregory124
take it back to who did the tint......they should fix it with out question
Old Aug 13, 2008 | 08:25 AM
jgregory124
I havent had any issues with my window tint
Old Aug 14, 2008 | 01:07 AM
r26's Avatar
r26
most likely it wasn't fully squeegeed when first applied. you only need to wait two days max after a tint job. one week is overkill.
Old Aug 14, 2008 | 03:05 AM
Z04's Avatar
Z04
no, because on my old car when i got the windows tinted by installed told me not to manually roll down the windows for a coupel of weeks to prevent that from happening. had the car for 3 years after that and no problems at all.
this could also be a result of a crappy install
Old Aug 14, 2008 | 03:37 AM
Mize's Avatar
Mize
Your tint guy wasn't very good then. I had mine done in the morning and was able to put them down that evening w/o a prob. He removed the window fuse and used a heat gun on the lowest edge to prevent that while it was drying.
Old Aug 14, 2008 | 06:43 AM
McGuckin's Avatar
McGuckin
Thanks for the replys it was redone without issue. Pulling the winow fuse is a great idea.
Old Aug 14, 2008 | 07:28 AM
OldDirty Z33
Just remember to roll them down slightly like I_I much haha If you dont the window will hit the roof and create a small scratch.
bcoffee20
Nov 19, 2015 06:39 PM
juang20
Intake
Sep 7, 2015 05:37 PM
Jill
Oct 9, 2004 12:37 PM
lauderdale75
Nov 4, 2002 09:14 AM
jackkemp
Aug 27, 2002 06:01 PM
