Paintcode on PPW?
Old Oct 17, 2008 | 03:03 PM
AllStock's Avatar
AllStock
Default Paintcode on PPW?
I have a 06 PPW Z and I'm wanting to repaint the sideskirts, they are scraped up.. but the only paint code I could locate on the car was "QX1"
Is this the correct paint code? I have to go 2 pints of PPW paint and I want it to be sure it'll match the car. Also, does PPW have pearls in them?
I'm going to Sherwin Williams to purchase the paint.. FYI. Any help?
Old Oct 17, 2008 | 03:13 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
QX1. You can find all this info on the VIN tag on the sill panel on the driver side.
Old Oct 17, 2008 | 03:48 PM
AllStock's Avatar
AllStock
^ is that code all I need?? Does PPW have pearls in them?
Old Oct 17, 2008 | 04:16 PM
1001's Avatar
1001
yes it does.
Old Oct 17, 2008 | 05:07 PM
coachk's Avatar
coachk
QX1 is the right code...its a 3 step process, Base-Pearl-Clear
Old Oct 17, 2008 | 06:54 PM
Zivman's Avatar
Zivman
paint code will only get you close... without proper mixing and tinting, it won't be a perfect match. You will have to spray test panels and compare. You are getting a different brand paint and most likely spraying a tinted primer. All that and having a 3 stage process with metalic and pearl make a proper color match VERY difficult..
All that said, good luck
Old Oct 18, 2008 | 07:05 AM
coachk's Avatar
coachk
+1 I used PPG paint and its as close as you can get to a match.
Old Oct 23, 2008 | 01:37 AM
Armitage's Avatar
Armitage
Not sure what paint the body shop I went to used, but its a pretty darn good match.
Old Oct 23, 2008 | 07:30 AM
robbinsj's Avatar
robbinsj
I had to hand over the gas cap for a perfect PPW match, it is the most difficult color to match I hear.
Old Oct 23, 2008 | 10:54 AM
ParanoidAndroid's Avatar
ParanoidAndroid
more than likely if you were to order some QX1 (PPW) over the phone or mouth the color of the base coat will come out too white, the mid coat (pearl) will be ok. so if your doing the paint yourself you should take your gas cap off your car and take it into the paint store and they should be able to mix the right base coat for you. dont use sherwin williams, it is a low grade paint. and you should only need about 1 pint to do both side skirts. 1 pint mixed 1:1 with base and reducer will make you 2 pints.
Old Oct 23, 2008 | 11:02 AM
JasonZ-YA's Avatar
JasonZ-YA
or instead of driving around with out your gas cap you can take your bumper mud flap/splash gaurds pieces or whatever they are called off and give paint shop to help them match it.......thats if your car is so equipped with them..
- J
Old Oct 23, 2008 | 11:03 AM
JasonZ-YA's Avatar
JasonZ-YA
and YES only use PPG paint!!! PPG - DBC...
- j
Old Oct 23, 2008 | 11:05 AM
ParanoidAndroid
^same thing. take 5 min. to take gas cap or splash guards off, you could do them in the parking lot of the paint store.
and the reason we use gas cap bc it has to be a flat surface for the computer to read the color. the splash guards aren't exactly flat, so there goes your theory.
Old Oct 23, 2008 | 11:24 AM
Entaille's Avatar
Entaille
I let a painter "wing it" with just the paint code once, for le mans sunset.. wow was he off, way too dark. 2nd attempt they are getting my gas lid for sure.. lots of tough to match colors for the Z.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
kyin
Sep 29, 2015 06:57 AM
ksj
May 5, 2003 08:42 PM
WashUJon
Oct 6, 2002 06:07 AM
