Hid 6k's
Old Oct 26, 2008 | 07:15 PM
djwatts's Avatar
djwatts
Default Hid 6k's
what do you guys have on your lights? post up any pics including talights and front lgihts, specs on parking lights turn signals and hid placement.
Old Oct 26, 2008 | 09:21 PM
Escobar's Avatar
Escobar
I got 6K in mine...
Old Oct 28, 2008 | 12:50 PM
Jun's Avatar
Jun
Originally Posted by Escobar
I got 6K in mine...
+1
Old Oct 28, 2008 | 05:48 PM
djwatts's Avatar
djwatts
alright man show us some pics, of the whole setup you have going on, what brands?
Old Oct 28, 2008 | 06:12 PM
djwatts's Avatar
djwatts
quick question for you guys, being that i have the 07 Z would i need the hid conversion kit? or can i just buy the bulbs and place them where the turn signlas would go? no more turn signals?
Old Oct 28, 2008 | 06:17 PM
Allen331's Avatar
Allen331
Do some research please. This is almost too easy to answer. Your Z, being a 2007 model, comes with HIDs STOCK. There will be no need to buy a conversion kit.
Because you apparently don't know the basics, here is what I'd go for.
Phillips Ultinon 6000k D2S bulbs.
You don't place the HID bulb where the turn signals go...that'd make zero sense as you'd be flashing your HIDs everytime you signaled.
Pop your hood, disassemble the back part of your headlight...unclip your 4300k stock D2S bulb, pop in the new one...and you're done.
I'm not sure if you're aware of this...but your HID unit is completely seperate from your turn signals. Once installed, you'll still have your turn signals.
To operate your turn signals...simply push the left lever down for left, and up for right.
To turn on your headlights, turn in a counterclockwise motion 2 clicks up.
Old Oct 28, 2008 | 06:39 PM
djwatts's Avatar
djwatts
someone on here has hids on their turn signal location they dont use them for turn signals. the thing is he has them wired to be on when turning the ****. only question i asked was can you place them their and wire them differently?
Old Oct 28, 2008 | 06:57 PM
Sleeper01's Avatar
Sleeper01
put on your flame suit!
Old Oct 28, 2008 | 07:00 PM
TheOtherRob's Avatar
TheOtherRob
Someone has HID's in the turning signal spot?
Old Oct 28, 2008 | 08:52 PM
djwatts's Avatar
djwatts
yup, he has it posted on the exterior forums on like the 7th page. you guys should read up on it. it actually seems like a perfect spot with same color glow as the projectors
Old Oct 28, 2008 | 09:09 PM
TheOtherRob
Please for the love of god tell me that your not talking about this thread.
If so, please read the 14th post.
https://my350z.com/forum/exterior-in...heres-pic.html
Old Oct 28, 2008 | 09:37 PM
350zfun19's Avatar
350zfun19
wow... i hope you dont actually work on your own car.
Old Oct 29, 2008 | 07:54 AM
RanFerr_350z's Avatar
RanFerr_350z
They are not HID bulbs. The bulbs are acutually LED's called swithbacks. The LED is a combination blue LED AND amber. The amber is only activated when the turn signals are on. Also this mod will not work on 06+ models only 03-05 Z's
You see the 03-05 HID are different from the 06+ models. When you retrofit the 06 headlights to a 03-05 the wiring is different. The wiring in an 03-05 causes the signal light to stay on whereas on a 06+ they are obviously only on when activated.
So what some of us 03-05 guys did was take advantage of this and replace the OEM bulb with the switchback LED. The bulb stays blue until our signals are activated then it switches to amber. i did the same mod with my 06 headlights. Refer to the link posted below. I started a thread on it.
https://my350z.com/forum/exterior-in...tion-pics.html
Old Oct 31, 2008 | 07:25 AM
sam2944's Avatar
sam2944
Hello guys! No HID is available to turn signals, just LEDs lights. OEM Z's just replace the bulbs. For hi beams the entire conversion kit is needed. Please visit our online store WWW.SAGAHID.COM We have all you may need. 1 year warranty in HID kits including digital ballasts, plug & play and waterproof. If support is needed due to language barrier just let me know via pm or through the contact area of the webpage. Regards.
Pleask
Dec 21, 2021 03:17 PM
SirZaLot
Mar 4, 2003 12:34 PM
Daddy
Feb 4, 2003 11:13 AM
Mr Fairlady
Jan 28, 2003 06:08 PM
dvlad
Sep 15, 2002 07:48 PM
