LED Tail Lights - problems??
Old Feb 12, 2009 | 10:03 AM
tollboothwilley's Avatar
tollboothwilley
Default LED Tail Lights - problems??
I've been told that using some brands of aftermarket LED tail lights can cause problems, can anybody describe the problems or know anything about this?
Old Feb 12, 2009 | 10:08 AM
Z04's Avatar
Z04
besides getting laughed at for buying cheap led lights, i see no other issues
Old Feb 12, 2009 | 10:09 AM
WhiskeyHotel's Avatar
WhiskeyHotel
You mean electrical problems? Probably not. My guess is that some aftermarket lights are built rather cheaply, causing them to crack, leak, etc. And of course, some are just fugly.
Old Feb 12, 2009 | 10:11 AM
Spork's Avatar
Spork
Vehicles can experience electrical problems due to aftermarket LED taillights.
The Z is one of these.
Old Feb 12, 2009 | 10:24 AM
cheshirecat79's Avatar
cheshirecat79
Edited- added freads.
https://my350z.com/forum/maintenance...-sluggish.html
https://my350z.com/forum/maintenance...5000-rpms.html
This search button is amazing. I'm going to have to use it more for you.
Old Feb 12, 2009 | 11:30 AM
tollboothwilley
LOL
i searched for a good 30 min. I hate the search options on this site. I did finally find those threads before your reply though.
I guess some people are still in the dark as to this issue.
It doesn't matter if the LED tail lights are cheap...Even if they are expensive ones. OEM must have a resistor as part of light to keep it from causing the same voltage change.
Old Feb 12, 2009 | 03:40 PM
WhiskeyHotel
I've seen this stuff, but I'm not sure I agree with the explanation. There certainly was something going on there, but I also noticed the resistance value was never posted...
Old Feb 12, 2009 | 06:04 PM
sintaxeror's Avatar
sintaxeror
The use of the word "fread" really takes away from your sarcastic badassness.
Old Mar 11, 2009 | 10:38 PM
tollboothwilley
LED problem fixed.
https://my350z.com/forum/2003-2008-n...ml#post7063752
75ohm 5W power resistor in PARALLEL
Pink is +
Black is -
Old Mar 12, 2009 | 03:17 AM
cheshirecat79
Thanks for following up on this with the information on how to correct the issue.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
