Please help: interior/gauge light probem
Old Mar 16, 2009 | 01:54 PM
Boorad's Avatar
Boorad
Default Please help: interior/gauge light probem
Hello all, I have a 2005 350z bought it a year ago. Previous owner had changed all the lighting (heat/window switches/guages) to blue.
Now I find the Gas & engine temp and part of the tack are burned out along with one of the heat *****. Everything else is good.
Need to know what size bulbs/LEDS I will need to purchase to maybe take this on myself or bring to someone. and finnally how much this will roughly cost me.
Thank you in advance for any help
Old Mar 16, 2009 | 08:32 PM
Prone's Avatar
Prone
There's a LED genious that has a lot of good info on this matter. Search the forums for Acree and led. you will come up with your answer. Or you can PM him and try your luck that way. It sounds like you need new LEDs. The guy you bought the car from might have changed the resistors to a wrong value therefore overworking the LEDs. The LEDs you will need are PLCC. But i most warn you, if you don't have experience soldering really tiny pieces then get this done by a pro. Hopefully I helped guide you in the right direction. I'm by no means an expert in this subject. Good luck.
Old Mar 17, 2009 | 09:54 AM
Boorad's Avatar
Boorad
Thank you... you helped in a big way
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
