engine damper
Old Mar 20, 2009 | 05:10 PM
zcoupe's Avatar
zcoupe
Default engine damper
ok i cant believe there is nothing about these on this forum... anyway, can someone tell me if it makes any noticeable difference? if so what is the difference it made? im looking at getting the stillen one but not sure if it is worth the money. i bring my car to the track about 2 times a month and am looking for mods that are gonna make a difference. thanks in advance
Old Mar 20, 2009 | 05:14 PM
Gag83's Avatar
Gag83
It reduces engine movement pretty much
Old Mar 20, 2009 | 05:25 PM
zcoupe's Avatar
zcoupe
well i understand that but do you feel like the car is tighter when taking off and do you feel it putting more power to the ground?
Old Mar 20, 2009 | 05:29 PM
Gag83's Avatar
Gag83
Lol no your not gonna put more power on the ground with a metal bar that holds ur engine, its for weight distribution and and added security
Old Mar 20, 2009 | 05:48 PM
Spork's Avatar
Spork
Wat?
Engine dampers are to keep the engine more steady, which translates into a more steady engine/transmission. Benefits are minimal, if not non-existent.
Old Mar 20, 2009 | 06:14 PM
Gag83's Avatar
Gag83
overall its not gonna help, plus its not that cheap for what it does
Old Mar 20, 2009 | 06:47 PM
Fletch69z's Avatar
Fletch69z
Don't waste your money.
Old Mar 20, 2009 | 07:55 PM
Do you have 1,000 pounds of torque ripping the motor from the mounts?
Old Mar 20, 2009 | 08:00 PM
Flick Montana's Avatar
Flick Montana
I bought some dogbone dampers for my old Saturn when I turboed it. I went from having my engine flop around like a cack with the rubber dampers to destroying the metal ones. They went oval after a few days at the track. I'd say skip the mod unless you're putting down major power.
Old Mar 20, 2009 | 08:21 PM
zcoupe's Avatar
zcoupe
ok thanks for the input. i had put motor mounts in my old car and liked the result but hated the vibration at idle. was hoping a damper would give similar results with out the vibrations. guess not
Old Mar 20, 2009 | 08:24 PM
zcoupe's Avatar
zcoupe
i understand its not a hp adder but they say that the movement of the motor is wasted momentum so when installing one it gets rid of the wasted energy to put more power to the wheels. not like it adds hp or anything just uses wasted momentum
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
