I installed a 2003 350z engine on a 2005 nissan 350z body. The car runs awesome and drives like new we installed everything correctly every part in the new Z is from the 2003 except the body and suspension. The problems is all the lights in the dashboard are on, the engine, airbags, traction control and the speedometer does not work. How do I get rid-off those lights? How do I get the speedometer working?
There the same exact wiring hardness from the 2003/2004. And yes I ran a scan on it and I had 6 codes. The car is good, but according to the codes is not. Its there a way to delete the codes?
Yes. There should be a clear codes option on your scanner.
