What to do with the tow hook hole?
Old Apr 10, 2009 | 06:36 AM
ZKansasZ's Avatar
ZKansasZ
Default What to do with the tow hook hole?
For people with after market front bumper, what would you do to cover it beside putting the tow hook in?
Or it is ok just to leave it like that?
I appologize if not searching hard enough about this topic!!
Old Apr 10, 2009 | 06:47 AM
Brrcats's Avatar
Brrcats
nothing
Old Apr 10, 2009 | 06:58 AM
G4L-MEL's Avatar
G4L-MEL
I would put a tow hook in. But I just like that look.
Old Apr 10, 2009 | 07:49 AM
350z 6spd's Avatar
350z 6spd
On my nismo the factory painted it black so it blends in with everything else behind the bumper
Old Apr 10, 2009 | 08:52 AM
zcar_dad's Avatar
zcar_dad
I screw my front plate holder into it and the plate hides the hole very nicely.
Old Apr 10, 2009 | 09:47 AM
ZKansasZ's Avatar
ZKansasZ
holy cow it has been a while, sir! How are you doing?
Old Apr 10, 2009 | 10:12 AM
GT47R's Avatar
GT47R
I didn't do anything to mine.
Old Apr 11, 2009 | 04:05 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I like the hook to be in, partly for looks and partly for emergencies just in case it needs to be used.
Old Apr 11, 2009 | 08:55 PM
boosted99gst's Avatar
boosted99gst
put a powdercoated, color matched folding tow hook in it! or leave it balck to hide the hole.
Old Apr 11, 2009 | 09:08 PM
TheOtherRob's Avatar
TheOtherRob
Im going to paint the tow hook hole black to make it blend it. And I will probably have to install my tow hook and keep it in since I believe you cant screw it in with the amuse front on.
Old Apr 11, 2009 | 09:09 PM
boosted99gst
whatsup rob? im feeling a headlight mod coming on soon, you down?
Old Apr 11, 2009 | 09:17 PM
06z33's Avatar
06z33
I did the same. But is yours straight? It seems like mine is always slanted because of the wind during highway speeds.
Old Apr 12, 2009 | 06:19 AM
TheOtherRob
Everyone's oem tow hook from what Ive seen does sit at an angle when fully screwed in. When I do mine, I am going to use a drop or less of some loctite to keep it sitting straight. Just an idea.
Old Apr 12, 2009 | 06:20 AM
TheOtherRob
LOL, I will never do headlights again. But I can give you some advice if you attempt to DIY. I have a life long scar from doing mine...
Old Apr 12, 2009 | 12:02 PM
06z33's Avatar
06z33
Sounds like a good idea. I've tried to come up with different things to make it sit perfectly straight (a ton of things I got from home depot). If you have any success be sure to post pics
Old Apr 13, 2009 | 11:56 AM
Chebosto's Avatar
Chebosto
no need to cover it really... you could always think about rotating the beam 180degrees so the hole is up, but then you risk not getting access to the tow hook hole when you really need it!!
Old Apr 13, 2009 | 12:49 PM
Done Deal DR's Avatar
Done Deal DR
2 Questions for you: with your C-West bumper did you paint the tow hook area black or leave it as is, and did you still use the foam impact piece (seems sort of worthless on this bumper, even looks like it may fall out on it's own).
Thanks Cheston, I appreciate your words of wisdom.
Old Apr 14, 2009 | 09:13 AM
Chebosto's Avatar
Chebosto
i have the foldy autotechnic tow hook installed.. and no foam piece (it won't do much except fall off since there isn't any pressure from the bumper to keep the foam on)
you can sorta see it here:
Old Apr 14, 2009 | 09:43 AM
Done Deal DR
Thank you!!!
Old Apr 14, 2009 | 10:32 AM
terrasmak's Avatar
Install it , then use it, actually try not to use it , but go to the track. Driving>posing
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
350z82
Oct 1, 2015 06:25 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
