Stock Wing Question
Old Sep 24, 2003 | 09:14 PM
only1's Avatar
only1
Default Stock Wing Question
Where exactly do we put the stock wing on at?.....how far from the edge?...any pics?
Old Sep 25, 2003 | 08:52 AM
only1's Avatar
only1
I know someone has to know! ANyone!..BUMP
Old Sep 25, 2003 | 09:02 AM
ares's Avatar
ares
Veteran
should have gotten a paper templete to give you drill locations.
Old Sep 25, 2003 | 10:45 AM
only1's Avatar
only1
Well, i purchased it from someone off this forum. Im not going with the drill, but the 3m tape which many people said could be used.
Old Sep 26, 2003 | 10:13 AM
Wedge's Avatar
Wedge
Here is a link to the installation instructions, but as ares said, it requires a paper template. Just use these to get an idea of where it should go.
http://www.courtesyparts.com/instruc...RRSPL_pg1.html
In your case, I would get a roll of the blue 3M painters tape, then use that to mark a guideline for where I want the spoiler to line up. Then I would take the spoiler with the double sided tape on it and carefully allign it with the blue tape and hope it goes on straight.
Make sure you use a wax remover on the area that you will be taping, then let the double sided tape cure for a couple of days before you let the vehicle get wet. (rain, car wash....etc.)
If a wing slams into my windshield some day.........I will know there is a reason they come bolted on from the factory........lol
Good luck with the install!
Old Sep 26, 2003 | 10:30 AM
havabooz's Avatar
havabooz
itll be fine with just tape...trial and error is the best method
however it will never be PERFECTLY down on the car unless you get it drilled
Old Mar 14, 2005 | 11:45 PM
BlkZed's Avatar
BlkZed
Do you guys have any recommendations for body shops near the Irvine area where I can get a rear spoiler installed? Also, are the templates of both the oem spoiler and the one from spoilerdepot.com identical? In other words, are there more holes to be drilled for either spoiler?
Old Mar 15, 2005 | 09:22 AM
OP Z's Avatar
OP Z
If you have the OEM spoiler, then all you need to do is remove the finisher on the hatch and there are 2 holes where the outer holes on the spoiler line up. If you drill your hole in the center of those holes the spoiler will line up perfectly.
I know it's a bit nerve racking, but I did it myself with no problems. There are others in this forum that have used this method as well.
Old Jun 11, 2005 | 11:20 PM
jinsei888's Avatar
jinsei888
do u guys know if the dealership sells just the paper template alone? or if anyone on the forums still has one to share?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Paul.
Oct 16, 2015 07:34 PM
torchkc
Sep 11, 2015 08:26 PM
etong
Sep 10, 2015 06:14 PM
