headlight full of water
Old Jun 8, 2009 | 09:23 AM
stewieisslow's Avatar
stewieisslow
Default headlight full of water
went out to my car today after a storm and my driver side headlight is full of water....im guessing i have to replace the whole headlight right? there is no cracks or anything in the headlight so i have no idea how water got in but the headlight does not turn on anymore...it is an HID by the way....what do i do?!?!?
Old Jun 8, 2009 | 10:03 AM
AdvanZed's Avatar
AdvanZed
Edit: I just saw that you said the light won't come on anymore...
Uhm most likely the bulb just fried. Try flushing out the headlights cleaning them out and sticking a new bulb in there. If that works just make sure this time you seal it properly so it doesn't happen again.
Old Jun 8, 2009 | 10:34 AM
stewieisslow
i went to the dealer and they told me i needed a whole new headlight and everything but that was just from looking at the outside...do you think they were just trying to take my money?
Old Jun 8, 2009 | 10:42 AM
kevincat's Avatar
kevincat
its likely that the ballast is dead. bulb should still be working. seal the head lights back up and dry the ballast out.
i had a similar case to you and changing the ballast out solved the problem
oh and it doesnt take much for water to get in. check around to see if there is any puncture in the back or front. then make sure if the back cover (round plastic top) is on correctly.
gl
Old Jun 8, 2009 | 11:40 AM
Xlr82x's Avatar
Xlr82x
sounds like this would be a great time to do a headlight mod...
Old Jun 8, 2009 | 11:51 AM
ZS14RR's Avatar
ZS14RR
i also had the same problem....
it was just the ballast luckily i had a extra one lying around.
jus swap out ballast and u should be fine regarding light.
now having a fish tank for a headlight ur on ur own.
Old Jun 8, 2009 | 01:29 PM
nismonian's Avatar
nismonian
i thought headlights were covered under warranty?
Old Jun 9, 2009 | 11:12 AM
AdvanZed's Avatar
AdvanZed
gl
My first guess wouldn't be the ballast. Why would the ballast fry the one time that water actually got "inside" the headlight. It's a possibilty sure but I'd say first try the bulb to make sure the ballast didn't take a dump.
Old Jun 9, 2009 | 11:46 AM
kevincat's Avatar
kevincat
its likely its the ballast and not the bulb. the water would short the ballast first. unless you lights are filled with water which is unlikely. just take it apart and dry the ballast out.
dont let it sit too long wet or it will no longer work
Old Jun 9, 2009 | 11:48 AM
kevincat's Avatar
kevincat
oh and the ballast sit underneath the lights. and the part where it has electrical connection is right there open to water, if there are any, inside the lights. so its not hard to see that its the ballast that took a dump and not the bulb. you cant really short the bulb and less you submerged it in waters.
Uriyo_
Sep 8, 2021 08:46 AM
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
