Front license plate removal
Old Jul 22, 2009 | 08:19 PM
J. Dub's Avatar
J. Dub
Default Front license plate removal
I'm lookin to purchase this 2007 350Z from out of state. It has a front license plate holder. My state doesn't require it and I will be taking it off. But I'm wondering if there will be holes in the front bumper if I take it off?
If there are holes in the bumper I'll move on till I find a Z that doesn't have the front license plate attached to it.
Thanks for help in advance.
Old Jul 22, 2009 | 08:24 PM
HDPDZO6's Avatar
HDPDZO6
Not difficult or expensive to plug the holes.
Old Jul 22, 2009 | 08:43 PM
J. Dub's Avatar
J. Dub
So there will be holes. I was hoping it was held on by a bracket that came from the front stock lip area.
I'm not wanting to plug the holes cause then there will be an outline much like in the pic below of this genesis. Notice the circle below the headlight but above the front bumper "whiskers".
Old Jul 22, 2009 | 09:09 PM
vthao's Avatar
vthao
The holes can be professionaly filled and painted for cheap. I'm not getting the genesis picture though, looks nothing like the Z does.
Old Jul 22, 2009 | 09:15 PM
gregom's Avatar
gregom
I think that hole there is for the Genesis Coupe's tow hook. It is supposed to be like that. If you plug plate mount holes properly you wont see anything at all.
Old Jul 22, 2009 | 09:43 PM
HDPDZO6's Avatar
HDPDZO6
Well, your choices are small holes which are very easy to plug or dimples, where the holes would be drilled.
Have you even seen a 350Z up close?
Old Jul 23, 2009 | 05:58 AM
diablox1's Avatar
diablox1
personally, i wouldnt pass up a Z i wanted just because of license plate holes in its front bumper. (1) they could be professionally plugged and (2) you could replace/paint a new bumper for relatively cheap. but to each his own.
Old Jul 23, 2009 | 11:39 AM
VO...'s Avatar
VO...
Administrator
They make little painted rubber plugs to put in the existing holes. I saw them a couple years back here on the forum. Can't remember where...
Old Jul 23, 2009 | 11:50 AM
MarvinMartian's Avatar
MarvinMartian
http://www.bumperplugs.com/BPindex.html
Or . . . .
Go to Lowe's and buy some 5/16" nylon plugs.
Go to the dealership and buy a bottle of touch up paint.
Go home, and paint the nylon plugs.
Pull off the license plate holder. My bumper had two holes from the holder, and two gouge marks from the screws used to attach the plate.
Drill out the holes with a 5/16" drill bit.
Pop the freshly painted nylon plugs in the holes.
Voila.
EDIT: I had originally said to use 5/8" plugs. My mistake.
Just found the pics I took during the install; I had used 5/16" plugs and bit.
Oops.
Old Oct 24, 2009 | 07:11 PM
sfearl1's Avatar
sfearl1
Or . . . .
Voila.
Oops.
can you post some pics of the finished product please?
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
