350z dash ?
Old Jul 28, 2009 | 07:10 AM
skarakis007's Avatar
skarakis007
Default 350z dash ?
I have a 2004 350z
i want to put a 2006 center consloe in it
will this work or will i have to change the wiring harness
i have an auto car i want to change the radio, center, shift bizl
i heard the 2006 & up u can change the rpm in the gauge but u cant in mine thats why i ask. Let me know thanks
Old Jul 28, 2009 | 08:22 AM
04zee's Avatar
04zee
in my 04 6mt you can change the rpm i dont know if its the transmission or what not, but i think you should be able to change the rpm with the lower button on the right side of the speedometer.
Old Jul 28, 2009 | 09:14 AM
scotts300's Avatar
scotts300
Sounds like the OP wants to change to the newer console, not just increase where his shift light comes on.
Old Jul 28, 2009 | 09:45 AM
Guilty1s's Avatar
Guilty1s
i dont think the auto trannies have shift lights anyways
Anyways i am 99% sure you have nothing to worry about. Should be the same wiring. The only difference is where the redline part is. 03-05 is 6.5k and 06 is 7k.
now 07-09 you do need to worry about it, cause the tach goes up to 9000 while 03-06 goes to 8000.
Wait... i just read why your doing this.. now im confused...
What are you trying to do or change?
Old Jul 28, 2009 | 12:38 PM
skarakis007
I like the new style center dash. I want to change it but dont know if i need to stay away from the mt one cause u can change the rpm unlike the auto kind.
Old Jul 28, 2009 | 01:05 PM
Guilty1s's Avatar
Guilty1s
got you... you can use a mt for your car. The proccession computer is that little white box behind your hvac controls.... the button on the cluster is just a button. You won't notice.
I didnt know there was a difference in the 06 and up clusters... what is it.
I dont know if you would be interested but i think am going to start going color conversion for the z for some people. It will look like this....
or what ever color you want
Old Jul 28, 2009 | 02:07 PM
Waiz's Avatar
Waiz
You want to change the gauge cluster or the whole dash?
From the way your post was constructed I would advise you to do some research and use the site search function, this is alot more complicated than you think.
I'm not sure about the cluster, but if you want to change the center console, you will need to change the entire setup from the triple-gauge cluster to the cup holder past the emergency brake.
Old Jul 29, 2009 | 10:57 AM
Guilty1s's Avatar
Guilty1s
but also you wouldnt have a screen for your tiptronic gear but there would be a not working shift light. I have a slight feeling the shift light would turn on when you have it in tiptronic mode. Like stay on but no LCD to make the number. Not like a shift light.
What is the difference in years for the cluster... i cant fiqure it out?
Old Nov 2, 2009 | 11:53 AM
5488201's Avatar
5488201
How do you go about converting your guage lights to blue, like on the pictures.
Old Dec 5, 2009 | 12:53 AM
350monZter's Avatar
350monZter
Default Are you going to do this for people on forum?
I'm down...how much
Workshop12
Mar 23, 2020 01:45 PM
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
Vigman
Nov 17, 2015 04:34 AM
codek
Sep 28, 2015 03:03 AM
