gas shocks for hood???
Old Oct 3, 2003 | 10:21 AM
350ZTN's Avatar
350ZTN
Default gas shocks for hood???
Anyone do away with the ugly prop rod for the hood and go for modded gas shocks for the hood. I'm thinking of doing this, and looking for pics.
Old Oct 3, 2003 | 10:24 AM
djkern's Avatar
djkern
i'd definitely do this if i could find some good pics of the procedure!!
Old Oct 3, 2003 | 11:13 AM
srobert910's Avatar
srobert910
I'm pretty sure that nissan didn't install gas shocks on the hood because it's so light. Think about it, it would be very easy to damage the Aluminum hood by trying to slam it down.
Old Oct 3, 2003 | 03:59 PM
whatever's Avatar
whatever
Veteran
looks like there are mounting points on the side of the hood for the gas struts. Just not sure what to use. Then again, with aluminum hood we have, I'll be afraid of it getting bent because of no support on the tip of the hood (ie prop rod.)
Old Oct 3, 2003 | 04:07 PM
AndyB's Avatar
AndyB
Default Reasons
I can think of a few reasons Nissan didn't use them.
Added cost
Added weight
Possibly not enough clearance
Possible bending of lighweight hood.
If it is just the first two reasons then it should be a possible upgrade. However, figuring out the angles, clearance, mounting points, and spring pressure required would probably take some trial and error. (unless some already makes a kit)
I would also be affraid of bending the hood while working the kinks out of the system.
But I bet the first person who comes up with a good kit could sell a bunch of them.
AndyB
Old Oct 3, 2003 | 07:25 PM
jminor's Avatar
jminor
Default Gas Hood Struts
I purchased after-market gas struts for my Miata and it worked very well. There was very little additional pressure required to close the hood. If one were designed properly with good attachment points I'd buy some in a second.
Old Oct 4, 2003 | 04:18 PM
zzzya's Avatar
zzzya
I know that some have already done this. I have seen pictures of Zs with them installed. I also thought it would be nice to have them, but have not seen anyone write up an install.
Old Oct 8, 2003 | 08:11 AM
Juggernaut's Avatar
Juggernaut
I'd like to have them....
Any ideas on where to find them?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
