Stock HID Question
Old Sep 9, 2009 | 07:14 AM
MrWatchDawg's Avatar
MrWatchDawg
Default Stock HID Question
I have an 05 Z roadster and has the stock HID. I was wanting to change the bulbs out to something a little bit brighter? Maybe 8000k. What would you recommend? and what brand
Old Sep 9, 2009 | 08:54 AM
WillyP28's Avatar
WillyP28
I have 8000K on mine and it def looks alot better. I know ebay has alot of garbage, but I bought mine on there for $60 from MotoringMax and have not had one problem yet.
Old Sep 9, 2009 | 10:00 AM
Thermal1's Avatar
Thermal1
That number 8000K is a temperature. The temperature measures the color, not the brightness.
I have 6000K in my 06+ lights and I like it. They are very white with just a hint of blue. 8000K will be somewhat more blue and output slightly less light. Just so you know.
Old Sep 9, 2009 | 11:30 AM
TheFarmer's Avatar
TheFarmer
Generally the more k's the less light output. If you want brighter lights, get more wattage but more wattage is illegal in a lot of states.
Old Sep 9, 2009 | 09:07 PM
sry110's Avatar
sry110
For HID I believe a higher wattage bulb requires a higher wattage ballast, and then you also have to look at all your wiring to make sure it can handle the higher power. If I remember correctly most HID systems are 35 watts and the more powerful brighter oes are 55 watts. Cant remember.
Old Sep 9, 2009 | 09:24 PM
MrWatchDawg
So if i get a 8000k 35w. Will it be better. i just wanna get something that had a little bit more blue
Old Sep 9, 2009 | 11:31 PM
S12 driver's Avatar
S12 driver
No, 8000k 35w would be dimmer than stock. If you want to keep the stock brightness but something bluer, you'll need to get a 55w 8000k kit.
Old Sep 10, 2009 | 08:24 AM
MrWatchDawg
so that means I will have to replace the wholle HID kid than?
Old Sep 10, 2009 | 09:02 AM
Thermal1's Avatar
Thermal1
8000K 35w will be fine for what you want. It wont really look dimmer, just bluer.
Technically, yes: it is outputting less light, but you wont notice because your bulbs will look so nice and blue
Old Sep 10, 2009 | 09:18 AM
MrWatchDawg
sounds good than thats all I wanted to know. Whats the stock bulb at?
and whats a good one to buy that would F*** up my car
Old Sep 10, 2009 | 09:37 AM
Jun's Avatar
Jun
8000K won't be brighter.
Old Sep 10, 2009 | 12:25 PM
Z_flip's Avatar
Z_flip
Yes 8000k won't be brighter, but it'll be towards white/blue ... The less K the brighter it gets. Usually 3k - 6k would be nice. I have 6k on my vehicles and they illuminate the road real good without giving that aftermarket looks. You might want to also check out the 55w kits they have now =]
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
