OEM Shift Knob Removal
Old Feb 6, 2006 | 12:10 PM
  #41
boogiemyke's Avatar
boogiemyke
Originally Posted by Ed 718
that is not true if you twist the shaft enough it will break ...do a search and find out and I know you have been around since 03 so your not a noob but the metal that holds the shaft is flimsy Myke. I remember someone had damaged it twisting it and the tsb even states you must hold the bottom part to keep it from twisting ....
Really? People have broken them???? That's pretty crazy. I didn't know that had happened. The metal looks pretty stout underneath. At least like it could handle breaking some lock-tite loose.
My apologies.
Old Feb 6, 2006 | 01:37 PM
  #42
z350boy's Avatar
z350boy
Originally Posted by sleeperZ69
I tried unscrewing the OEM shift **** on my 03' Z, but its really damn stiff! I used a vicegrip to hold the shifter rod from turning, and used another wrench with a cloth around it to remove the shifter. It was all going good until i hear a cracking sound. This could have been the **** starting to turn loose, but i didnt want to end up breaking anything. Does anyone know if that cracking sound is supposed to happen, or do you really just have to go ahead and apply that much force? I dont really want to ruin my OEM shifter, but if its gotta go, its gotta go, lol.
Let me know what you guys think.
thanks
I removed my shift boot to change the shift boot cover. YOU CAN DO SERIOUS DAMAGE TO YOUR TRANSMISSION IF YOU ARE NOT CAREFUL !!!
You should have a vise grip with an inner tube wrapped around the base of the shaft to hold the bottom steady. DON'T OVERTIGHTEN!! A firm grip is all that is needed. It might take a while but keep turning counterclockwise !!
Old May 6, 2007 | 06:23 PM
  #43
twitch579's Avatar
twitch579
Default Manual Shift **** removal?
Used the search feature and nothing comes up. Anyone tell me how to get it off??? Do I have to hold the shaft and turn like hell???
Im replacing with a new stock ****.
Old May 6, 2007 | 06:36 PM
  #44
Insanemonkeyboy's Avatar
Insanemonkeyboy
Here you go!
https://my350z.com/forum/showthread....threadid=25516
Old May 6, 2007 | 06:37 PM
  #45
wynd d z33's Avatar
wynd d z33
well i bought this rubber gripin device so it wouldnt damage it much and hold the shaft and turn the hell out off it... did a nice job wat kind of shift **** you goin to replace wit oem?
Old May 6, 2007 | 06:51 PM
  #46
twitch579's Avatar
twitch579
Just another stock one. The original is in pretty bad shape from previous owner. Its like destroyed and peeling apart. I really like the oem shifter.
Old May 6, 2007 | 11:09 PM
  #47
wynd d z33's Avatar
wynd d z33
i like them too but i like the nismo one is small and like the round shape lol i have 2 oem from my z's use them as patter weights lol
Old Apr 1, 2008 | 03:18 PM
  #48
trojanplayr's Avatar
trojanplayr
Default HELP!! needed w. the removal of the shift ****
hey guys.. Im in need of some instructions on how to remove the shift **** on an 03 manual.. please help
thanks
Old Apr 1, 2008 | 03:19 PM
  #49
Mr.'s Avatar
Mr.
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/207539-diy-install-shift-knob.html
Old Apr 1, 2008 | 03:22 PM
  #50
SpoilsofWar's Avatar
SpoilsofWar
Prepare for a struggle. lol
Old Apr 1, 2008 | 03:24 PM
  #51
trojanplayr
thanks buddy
Old Apr 1, 2008 | 04:37 PM
  #52
Escobar's Avatar
Escobar
Be Sure to use the Search feature first, as the topic may have been posted already.
did you happen to see that when you started this thread?
  #53
350ZTheStandard's Avatar
350ZTheStandard
Good Luck mine was a b*tch to remove even following the instructions, guess they used loc tite when installed at the factory
Old Apr 1, 2008 | 06:58 PM
  #54
IndyZ-man's Avatar
IndyZ-man
Just did mine on my 03 Touring 6speed. Was a little nervous at first, but used the vise grips with rubber bands for the main shaft and a strap wrench on the oem shift ****. Worked perfectly. Good luck!
Old Apr 1, 2008 | 09:43 PM
  #55
Escobar's Avatar
Escobar
I dont know, I guess I got lucky but mine came right off with just my hand.
Old Jun 11, 2008 | 07:45 PM
  #56
RobO350z's Avatar
RobO350z
Default 2008 Z Shift **** Removal
Hey I read the DIY's for the older models but do the 08's require anything different? My **** is coming in tomorrow and im stoked
Old Jun 11, 2008 | 07:46 PM
  #57
rickyislaZy's Avatar
rickyislaZy
It is the exact same way as any other year.
Old Jun 11, 2008 | 07:48 PM
  #58
RobO350z's Avatar
RobO350z
Ok thank you
Old Aug 14, 2011 | 12:35 PM
  #59
dmorrow's Avatar
dmorrow
Mine does not want to come off and its scaring me to be honest. ive had vise grips on the bottom of boot on the metal thing. and ive tried twisting **** even using channel locks and it seems its doing nothing. im feeling something spin. but dang. ive spent like 20+ minutes on it already and i feel like ive f`d up. i drove car around, trans. still works fine.
idk.
Old Feb 7, 2012 | 07:09 PM
  #60
ChinoZ33's Avatar
ChinoZ33
Default 03 shift **** removal
So I've been going at hanging my shift **** for 2 days, I've literally done exactly what it says on the how to's including lifting the console and clamping under the rubber above the insulation etc. still nothing. Can anyone shed some light on this?
