Window Drop Problems
Old Mar 9, 2010 | 07:02 AM
LuciaPwNs's Avatar
LuciaPwNs
Default Window Drop Problems
I noticed that the passenger side window isn't dropping when the door is opened or going up when door closes. I was just wondering what some possible problems could be that are causing this. Just so i know what to look for when i rip the door apart.
p.s.
Window still works with manual controls
Old Mar 9, 2010 | 08:17 AM
flecko28's Avatar
flecko28
Does you dome light come on when you open the same door?
I believe the switch that turns the dome light on when you open the door also activates the window going down a little bit when you open the door. Someone please chime in if I have been mislead and am in turn misleading others.
If the dome light doesn't come on, then that switch may be the culprit.
TJ
Old Mar 9, 2010 | 01:09 PM
LuciaPwNs's Avatar
LuciaPwNs
TJ
hmm i dont know. ill have to check that out next time i get in.
Old Mar 10, 2010 | 06:16 AM
LuciaPwNs's Avatar
LuciaPwNs
The dome light does turn on when i open the door =(
Old Mar 10, 2010 | 06:31 AM
Unique_Z33's Avatar
Unique_Z33
Your window motor is starting to go. Or you simply need to recalibrate it. Im guessing its starting to go cause mine did the same thing. It just got worse. I ended up having to replace it. There is a DIY for it. Good luck!
Old Mar 10, 2010 | 07:04 AM
flecko28's Avatar
flecko28
Hope that will fix it for you! Good luck!
Old Mar 10, 2010 | 10:32 AM
LuciaPwNs's Avatar
LuciaPwNs
Old Mar 10, 2010 | 10:33 AM
LuciaPwNs's Avatar
LuciaPwNs
maybe ill try cleaning the motor first. The window drops down half way when ever i put it up using the automatic option and sometimes when the door closes
Old Mar 10, 2010 | 11:13 AM
Unique_Z33's Avatar
Unique_Z33
That was my exact problem. Your motor needs replacing. Granted you maybe able to clean it and it'll work properly for maybe a month. I say just replace it and be done with it. Nissan's widow motors are FTMFL!
Old Mar 10, 2010 | 12:34 PM
LuciaPwNs's Avatar
LuciaPwNs
Ok thanks!
Uriyo_
Sep 8, 2021 08:46 AM
