Need Help: Installation of HID's in Base Model
Old Oct 29, 2003 | 04:44 PM
MrGraphics's Avatar
MrGraphics
Default Need Help: Installation of HID's in Base Model
I am going to create an HID kit (buy the ballasts and bulbs seperately) and install them in my Base. Question is: Can I run the ballast off the H7 connectors (one ballast per connector) - assuming I replace the fuses with 30 amp ones?
My friend has an Accord, and his kit had a relay, with a power line to the battery. Since I am piecemilling my own kit together, I will not have the relay.
Can the stock wiring handle the initial power/ignitor cycle?
Thanks for your replies. (I did a search and this specific question was never answered)
Old Oct 30, 2003 | 12:34 PM
Jun's Avatar
Jun
yes, they will handle the HID lights. I am running a set of HID on my base 350z. What i did was tap the connector that connects to the bulb (the one inside the headlight), i didn't even have to splice it, i just opened the plastic connector, inserted the ones from the HID so that it made contact with the metal and the original wires, squashed it together and closed the connector.
Old Oct 30, 2003 | 03:50 PM
MrGraphics's Avatar
MrGraphics
That's great. I guess that since our cars wiring was designed for HID's, all Nissan did for the base was change the connector plug and housing for the bulb (and ommitted the ballasts).
Thanks for the reply.
Old Nov 1, 2003 | 07:29 AM
Ralphus's Avatar
Ralphus
How much does it cost to do this, and where do you get the parts?
Old Nov 1, 2003 | 10:58 AM
kbomb's Avatar
kbomb
Jun,
what brand HID did u use? ALso, do u have a DIY thread for this?
Old Nov 2, 2003 | 12:01 AM
MrGraphics's Avatar
MrGraphics
http://www.visualdynamics.ca/
for raw parts
http://www.network54.com/Hide/Forum/216460?it=0
http://hidforum.com/forum/index.php?
for all info on HID
Old Nov 2, 2003 | 06:33 AM
Jun's Avatar
Jun
Originally posted by kbomb
Jun,
it's and HID kit from an Audi TT.
Old Nov 2, 2003 | 08:55 AM
StrictlyZ's Avatar
StrictlyZ
Unhappy
Don't mean to rain on anyone's parade... But aren't HID kits no longer legally for sale? Being a vendor we had a lot of companies approach us trying to clear them out.
Just curious if you can still get kits, which I'm sure there are some places you can.
thanks guys
Old Nov 2, 2003 | 10:05 AM
MY350Z.COM's Avatar
There are many places where you can still get the kits. Just search on google.
Old Jul 23, 2005 | 04:10 PM
munky350z's Avatar
munky350z
please clear this up for me... can regular d2r HID bulbs just plug in into our base lights ? or we need special h7 adapter ? Jun ?
Old Jul 23, 2005 | 05:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
No you cannot install D2R bulbs in base model Z.
Old Jul 23, 2005 | 06:15 PM
Acree's Avatar
Acree
actually, you CAN but your not supposed to. the D2S bulbs are so that a certain part of the light is blocked to reduce glare coming out of the housing. you would have to dremel part of the bulb base and housing, but a D2R bulb will fit. just do it right the first time and get the D2S.
Old Jul 23, 2005 | 07:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The base model has no HIDs at all... D2R / D2S are HID bulbs.
And you're wrong, by the way. The Z with HID uses D2R, not D2S.
Old Jul 24, 2005 | 09:48 AM
Acree's Avatar
Acree
ah, i had them backwards. but i thought that the base headlight had the same bulb socket? i do apologize for the mis-information.
Old Aug 4, 2005 | 10:06 PM
ecorona6's Avatar
ecorona6
What happens when you change your whole headlamp from your base model non-HID for a new headlamp with an HID unit? I know the base model headlight connector (plug) has 4 prongs and the HID healight has a 6 prong connector! How do you over come this?
From research I have established people have done this since the HID connector seperates the low and highbeam and also a negative wire thus having two additional prongs! My questions is where do I have to connect these two extra wires? I bought an HID headlight connector which I plan on splicing to my current harness so that I can connect and disconnect the HID headlight using an HID connector! HELP
Old Aug 4, 2005 | 10:39 PM
Donny_b's Avatar
Donny_b
I have a Base, and I got an HID conversion kit. I just let the guy know what kind of car I has the he sent everything. Install was easy. I dealer was on EBAY. I'm very happy with the setup. PM me if you want the info.....
db
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
