Replacement Shroud Underside of Headlights
on
I bought a 350Z Roadster used roughly a year or so ago. Soon it will need to go through inspection, but the passenger side low beam xenon headlight is now out. Replaced the bulb and it did not help, so the ballast is probably shot from moisture.
Yes, this is the root issue I need help with. I am missing 2 of the 3 parts that shield the area beneath the front bumper and above the front wheels from road moisture. As a result, my passenger side headlight got water in it. Where can I find aftermarket replacements for this? Before spending the money to repair what is damaged from moisture in terms of electronics, replacing the shielding so to speak seems like a good idea.
https://my350z.com/forum/exterior-an...view-pics.html
this was the only thing i could find. its new from arc i believe. However, i remember someone asking this question a while ago. I think its the wheel liner you are looking for, someone will chime in. You could try courtesy nissan/ the z store.
on
Check the classifieds theres a # of oem hid parts for sale. that shield wouldnt of kept moisture out water would of founds its way in there one way or the other. I would put a light coat of black silicone completely around the headlight housing.
on
Yes it is missing the passenger side wheel liner (front half). The passenger side light has not been cracked open to my knowledge. I always assumed the lack of a wheel liner is how water got inside the housing. When it is all said and done, I pretty much need a passenger side wheel liner, light housing, bulb, and ballast to make it work again. Ugh. $95 bucks for a wheel liner, eh? That isn't too bad.
