2008 350z prewired for Homelink??
Old May 13, 2010 | 10:33 PM
08350zboy's Avatar
08350zboy
Default 2008 350z prewired for Homelink??
Hi does anyone know if the 2008 350z Base model prewired for the homelink that's in the enthusisast/touring models? thanks
Old May 14, 2010 | 03:25 PM
corrado15's Avatar
corrado15
Doubt it. My 06.5 was not - however it's a pretty easy DIY to do, tapping into existing alternate wiring in the A-pillar. I bought a Homelink mirror off eBay for about $50 - took 30 mins to install, works a treat.
Search the DIY Interior section and you'll find the info you need.
Davy
EDIT: here's the link
https://my350z.com/forum/body-interi...2005-base.html
Old Jun 13, 2010 | 09:33 AM
08350zboy's Avatar
08350zboy
I have the pigtail wiring, is the harness already available under the headliner and A Pillar? or do we have to buy the harness to in addition to the wiring? I want to do this as plug and play and not splice anything. Thanks
Old Jun 14, 2010 | 03:56 PM
corrado15's Avatar
corrado15
You'll almost certainly have to splice into existing wiring in the A-pillar. My Base did not have a harness in the A-pillar the splicing literally takes 5 minutes - it's probably the easiest mod I've done after the shorty antenna.
Davy.
Old Jun 14, 2010 | 07:22 PM
Blck350z's Avatar
Blck350z
Do want!!!! let me know how it goes.... also I don't want to spend $200 for one... where did you say you got one???
Old Jun 16, 2010 | 06:48 PM
corrado15's Avatar
corrado15
I picked up a used mirror out of another Nissan (can't remember which - possibly an Altima) which has Homelink and a compass for around $60 delivered on eBay.
Hardest part was getting the original mirror out of my Z. Wiring in the new one took 30mins max.
Davy.
Old Jul 11, 2010 | 09:13 AM
dcains's Avatar
dcains
OK, just did my '08 base 6MT last night, with a GNTX-453 Homelink Autodimming Compass mirror. The male plug in the A-pillar harness has only two wires, a black (ground) and red (+12V constant), and they provide power to the vanity lights in the sun visors. But, the female end of that plug has 4 wires, which you'll see if you remove a few inches of the electrical tape. The black is still ground, the red is still +12V constant, and the green is +12V switched with the ignition. (There was also a white wire I didn't check with a meter, as I only needed the 3 wires already mentioned to hook up the mirror. I used three 3M Scotchlock inline connectors, and everything tucked away well under the A-pillar interior trim. The plug is the 10-pin type (as on the mirror), so you'd figure it would be just left unused in a base car, rather than have two of the pins power the visor lights, but that's how it was in my car.
So, it's a very quick job, and no cutting of the original wiring harnesses is required. FWIW, I bought the mirror harness from 'wembleysells' on ebay, as he's a fellow Z-owner. The used mirror came from eBay seller 'lkqonline', and while it was $100, it arrived in brand-new condition. This mirror is a huge upgrade from the stock mirror, and I'd recommend it highly.
Dean
PS. If you're buying a used eBay mirror, MAKE SURE it comes with the mounting screw. I couldn't match the thread at any of the local hardware stores I checked, and the screw head has to fit the recess in the mirror mount. Mine came without a screw, but 'wemblysells' was kind enough to give me one with the harness.
FWIW, I called the customer service line at Mito Corp first, and they gave me every excuse possible as to why they couldn't provide the screw or harness. They said each car company requests a different screw, and that the pin configurations aren't the same mirror to mirror. Pure BS, as I have since discovered.
Old Jul 16, 2010 | 12:16 PM
camlitlow's Avatar
camlitlow
Default Homelink
This is a writeup i did when I had my 3000GT. Dont worry about the temp probe parts as our cars already have a temp display. Its not a home link but is a autodim.
I just installed an Auto-Dim/Compass/Temperature rearview mirror out of a Saturn SUV. It’s a pretty easy install. You can get these from just about any GM that was equipped with them. There are 2 main styles. One is the 7 pin flat plug and the other is the 16 pin OnStar type plug. You will need the mirror, about 12 inches of the mirror harness, harness cover (if it has one), temperature probe pickup and 12 inches of its harness. I got mine from a local pick-n-pull for $4.50. You can get them on eBay but they can get pricey.
7-pin: (*required connection; **required if you have a temp display)
PIN 1 = POWER = +12 volts*
PIN 2 = CHASSIS, GROUND*
PIN 3 = BACKUP LIGHTS* (Disables Auto-Dim in reverse)
If not using the backup feature, connect this to ground otherwise auto dim will not function properly.
PIN 6 = TEMP SENSOR**
PIN 7 = TEMP SENSOR**
16-pin: (*required connection; **required if you have a temp display)
PIN 13 = POWER = +12 volts*
PIN 8 = CHASSIS, GROUND*
PIN 9 = BACKUP LIGHTS* (Disables Auto-Dim in reverse)
You will connect 4 wires to the mirror’s harness. Run two to the front of the car near the front of the radiator for the temperature probe so that it can read outside air temperature (I mounted mine to the radiator support). Make sure that it is not near a heat source as the readings will not be true. Run two wires to a ground and 12 volt accessory hot. Do not run to a constant hot as the mirror will run your battery down.
Hope this helps anyone looking to add this feature. I am not a mechanic and do not play one on TV so I do not take responsibility if you burn your car up or hurt yourself.
Old Jul 16, 2010 | 12:36 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Originally Posted by corrado15
Im glad my DIY is still getting put to use..
Old Jul 19, 2010 | 04:26 AM
camlitlow's Avatar
camlitlow
Wow, is that your DIY? You should be proud, I think I got alot of the write up off of a tahoe forum It definitely has made the rounds through the car forums.
Old Jun 8, 2011 | 12:25 AM
08350zboy's Avatar
08350zboy
so it sounds like I can't just plug and play this even with the stock wiring harness since an 08 base doesnt have the connections in tucked under the A Pillar?
Old Jun 8, 2011 | 12:51 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If you buy the mirror from mynismo.com it comes with a harness, shurely that should be plug and play no?
Old Jun 8, 2011 | 07:55 AM
08350zboy's Avatar
08350zboy
I just purchased a oem 08 homelink + the stock 08 harness so I'm hoping this will just plug right in
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
