Keyless entry issue...
Old Jul 27, 2010 | 11:03 AM
350smo's Avatar
350smo
Default Keyless entry issue...
Ok, I will try to keep this short. I lost my keys(dumbass I know.) Found a guy to make a new one and could not get the keyless entry to work. Tried doing the "stick key in 5-8 times wait for beeps, then turn key to acsessory/every other igniton option" and no luck. The "fob" has a remote signal and was activating the hazard lights but will not work(also new battery.) To top it off the hatch release does not work. I dont mind not having keyless entry, but i need acsess to my hatch! Also its a used 2008 Nismo with 40k, so no warranties. Any suggestions for either of these problems is greatly appreciated. I'm new here, hello eveyone and thanks.
Old Jul 27, 2010 | 12:08 PM
JTZ0327's Avatar
JTZ0327
Try checking the fuse
Old Jul 27, 2010 | 06:04 PM
isktarum's Avatar
isktarum
Not sure how to help you with your key fob issue but, as long as your doors are unlocked, you should be able to open the hatch by pressing the button just above the license plate.
Old Jul 27, 2010 | 06:33 PM
350smo's Avatar
350smo
I'll be damned, didn't know about the button above the license plate,worked perfectly, thanks. I will check the fuse and post if thats the problem.
Tochigi_236
Sep 27, 2015 03:40 PM
jlc280z
Sep 24, 2015 08:43 AM
KeepRT
Apr 20, 2003 10:59 AM
jelledge
Feb 6, 2003 08:53 AM
padam07
Sep 25, 2002 07:18 PM
