Tommy Kaira Shift Knob question
Old Aug 5, 2010 | 05:12 AM
Kuhan's Avatar
Kuhan
Default Tommy Kaira Shift **** question
How do you guys align the turtle to face forward? I'm not using a finisher. Thanks.
Old Aug 5, 2010 | 06:28 AM
Sickboy101's Avatar
Sickboy101
I aligned mine forward as in the pic you posted... makes the car go faster.
Old Aug 5, 2010 | 08:07 AM
User 42426's Avatar
User 42426
i don't have one, but that would probably make it look nicer
Old Aug 5, 2010 | 09:13 AM
DavesZ#3's Avatar
DavesZ#3
I made my own spacer to go over the threaded portion of the shifter. I got a brass spacer from Lowes, 0.375"IDx0.5"ODx1". I had to grind the ID out a little to get it to fit over the 10mm threaded section of the shifter. I cut it to about 5/8" long, slid it on the shifter so it fills the space between the threads and the expanded section of the shifter.
Then I screwed the TK **** on pretty tight. You can grind the end of the spacer to fine tune the length so the **** aligns properly.
Old Aug 5, 2010 | 01:56 PM
winchman's Avatar
winchman
What exactly is the advantage of having a $200 shift **** that looks like a fossilized mushroom that's been sprayed with aluminum paint?
Old Aug 5, 2010 | 02:52 PM
Sickboy101's Avatar
Sickboy101
You don't know what your missing...
Old Aug 5, 2010 | 03:29 PM
Voboy's Avatar
Voboy
turtle virgin
Old Aug 5, 2010 | 03:31 PM
DavesZ#3's Avatar
DavesZ#3
I was skeptical about them at first. Read my "review" here...
https://my350z.com/forum/exterior-an...hread-d-7.html
One thing I didn't mention, it is significantly shorter than the OEM ****, giving you the added advantage of a short-throw shifter.
Old Aug 5, 2010 | 04:19 PM
Kuhan's Avatar
Kuhan
Thank you. I'll give that a try.
Old Aug 6, 2010 | 12:53 AM
seekanddestroy's Avatar
seekanddestroy
I took the ends of zipties and stuffed them in the ****, dumbest thing I've ever thought of.
Old Aug 6, 2010 | 03:27 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Based on some of the comments in the other TKHB thread, I tried several different ideas before settling on the metal spacer solution.
Old Aug 6, 2010 | 04:35 AM
Kwame's Avatar
Kwame
Mine is on crooked as all hell with the turtle facing the drivers seat.
I guess I'm a bad owner.
Old Aug 6, 2010 | 06:09 AM
graffkid732's Avatar
graffkid732
Ha mine too. I was going to be posting this exact question up. I thought of making a spacer, but didn't know if there was a legit way of doing it. Guess a spacer is the legit way.
Old Aug 6, 2010 | 08:11 AM
DavesZ#3's Avatar
DavesZ#3
When you took your OEM **** off, surely you noticed that it used a metal spacer ring already. Unfortunately, it's too short to do any good with the TK ****.
Old Aug 6, 2010 | 10:19 AM
Kuhan's Avatar
Kuhan
^I didn't even see that there's a spacer on there already.
I have to take the **** out again after the car show tomorrow. In the meantime, the turtle has to do it sidewayz.
Old Aug 6, 2010 | 10:24 AM
DavesZ#3's Avatar
DavesZ#3
Your '08 may not have had one but the older ones certainly did.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
