Installing 03-05 headlights into my 07 harness, questions
Old Oct 8, 2010 | 03:06 PM
J. Dub's Avatar
J. Dub
Default Installing 03-05 headlights into my 07 harness, questions
I am selling my 2007 bi-xenon headlights. My question is not like all the other countless threads I keep finding.
I want to know what is needed to make 03-05 headlights work using my 2007 harness that is in my HR.
I know there are two types of 03-05 headlights.
a) HID 03-05 heads
b) regular halogen 03-05 heads
Is there any trick to get either of those to work w/ a newer model harness or is it straight up plug and play?
I don't care if the DTR lights don't work. I just need the head lights and the turn signals to work.
Old Oct 8, 2010 | 05:43 PM
hwcustoms's Avatar
hwcustoms
As long as they are wired up correctly they will work. You will need to repin them though. Follow the instructions below, but remember you are looking at the diagrams backwards because it is showing the in car harness pin configuration.
https://my350z.com/forum/exterior-an...base-03-z.html
Also you will need the plug off a set of 06+ lights to put on the 03 lights to plug to the in car harness.
hwcustoms's Avatar
hwcustoms
Edit*
I was gonna ask why you were doing it, but I saw you were selling the lights.
Old Oct 8, 2010 | 10:01 PM
SQBassHead's Avatar
SQBassHead
now is this only for NON HID 03-05 lights?
wouldnt HID 03-05 lights be plug and play? like it is when your upgrading... it will be the same visa versa right
Old Oct 9, 2010 | 05:04 AM
hwcustoms's Avatar
hwcustoms
Yes you are correct. If the 03 style are HID, then it will be plug and play. But if the op just buys a basic set, you will have to convert.
Old Oct 9, 2010 | 07:34 AM
J. Dub's Avatar
J. Dub
Ah, dually noted thank you, I will look for only those that have the HID's then
Old Oct 9, 2010 | 10:32 AM
Ruthless18x's Avatar
Ruthless18x
I see you are selling your lights, but why would you do that, especially on a later model Z that they came OEM?
Old Oct 9, 2010 | 03:28 PM
J. Dub's Avatar
J. Dub
^cause I'm trading in my 350 for a rustang. I know the stealership won't know the difference
Old Oct 11, 2010 | 11:58 AM
Blck350z's Avatar
Blck350z
oooh... sneaky sneaky
Old Oct 14, 2010 | 12:34 PM
J. Dub's Avatar
J. Dub
Sucks for whoever desides to buy my car from the stealership. Hope they know the difference.
m_0g
Jun 3, 2021 10:05 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Vigman
Nov 17, 2015 04:34 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
