Plasti-Dip Questions & Projects Thread
Old Oct 19, 2011 | 05:45 AM
  #181
BSERIEuS's Avatar
BSERIEuS
the best thing about this product is that it isn't permanent. you can mess up as many times as you want...and it just peels right off.
since i hate my exterior door handles so much...i've contemplated on doing it. but since its a high traffic area...i'm sure it will look like complete *** as time passes.
Old Oct 19, 2011 | 07:21 AM
  #182
sluggoZ's Avatar
sluggoZ
Old Oct 19, 2011 | 07:23 AM
  #183
moose350z's Avatar
moose350z
My door handles have held up great.
Old Oct 19, 2011 | 11:07 AM
  #184
ChrisR's Avatar
ChrisR
loving mine changed the whole car.. and love the fact that it comes off easily
I've had the truck for almost 2 months now and love her.
before... (when i had both before selling the Z)
After
Old Oct 19, 2011 | 11:47 AM
  #185
sry110's Avatar
sry110
Originally Posted by Waizzz
Looks good moose, +1 on those pics after you're done sry.
I'm having a hell of a time finding anyone around here that actually carries the aerosol matte black plasti-dip. I've tried Ace, True Value, Home Depot, all of which are listed on Performix's site as distributors, yet the employees at said establishments all look at me like I'm speaking Klingon when I ask if they have it. I guess I'm going to have to buy it online and have it shipped to me.
Old Oct 19, 2011 | 02:15 PM
  #186
mr. sparco's Avatar
mr. sparco
Originally Posted by SilverZ350
Questions for you, did you have any trouble when peeling off your masking tape and the plastidip peeling with it due to over spray? I had this happen to me, I am new to this, guess I could of used a spatula or something?
No, I took my time and sprayed it on in several coats. With each passing coat I would peel off the excess. I have a little bit of body work experience, it does take a bit of practice and getting used to.
Old Oct 19, 2011 | 02:18 PM
  #187
mr. sparco's Avatar
mr. sparco
My friend couldn't find any and this was the issue: Look in the paint department, sometimes it's up above in boxes and not displayed for some reason.
Old Oct 19, 2011 | 02:26 PM
  #188
Suwaidi's Avatar
Suwaidi
The dip looks sick. You just gave me an awesome interior idea =]!
Old Oct 20, 2011 | 08:23 AM
  #189
BSERIEuS's Avatar
BSERIEuS
you have done your exterior door handles???
thats what i was referring to. i want to try it out...but its getting cold out here in chicago and im not sure how the whole process of plasti-dipping will work with colder temperatures.
Old Oct 20, 2011 | 09:05 AM
  #190
07JimmyZ's Avatar
07JimmyZ
I've never heard of this stuff, I would love to use this for the scratches on the switch bezels and the waterfall cubby hole button... I'm assuming everything has to be sanded first?
Old Oct 20, 2011 | 12:27 PM
  #191
sry110's Avatar
sry110
Supposedly, no. It might stick a little better if the surface is sanded, but then again if you ever decide that you don't like the plastidip finish you can just peel it off and the surface will be in the same condition as it was before applying the stuff. I'm probably going to forgo the sanding and see how it fares.
Also, I read somewhere (maybe earlier this thread) that in order to get the cubby button out you need to remove the cubby door, which requires removing the entire center console. Doesn't sound like fun....I may try spraying some plastidip into a small container and brushing it on by hand with the button left in place.
Old Oct 20, 2011 | 01:21 PM
  #192
TPete19's Avatar
TPete19
Actually, the cubby button can be removed without removing the cubby door. You've got to use a stubby screwdriver, have small hands and be super careful not to lose the tiny screws.
Open the cubby door and locate all of the philips screws on the backside. The back panel will come right off along with the cubby button/mechanism. I've personally never done it this way, but having disassembled and reassembled the center dash 4 times now, I know how the pieces go together.
The easier route, however, would be to mask around the button and spray it.
Old Oct 20, 2011 | 03:05 PM
  #193
Daron's Avatar
Daron
Meh, just a simple badge and door handle job.
Old Oct 20, 2011 | 06:25 PM
  #194
orangeNblue's Avatar
orangeNblue
Default option
just tossing this in there.....
I've repainted my whole waterfall area. I didn't use plasti-dip tho. I wish I had taken before pictures but I used SEM paint. I've had really good luck with their products in the past, having painted several interiors. It's good for textured surfaces like the waterfall consoles and the cubby. I'm chiming in because the cubby button was completely worn down and I was able to just spray over it.
here is a picture of the after
Plasti-dip does look like a really great product tho! especially on door handles and exterior parts. what does it feel like as far as texture goes?
Old Oct 20, 2011 | 06:42 PM
  #195
moose350z's Avatar
moose350z
My door exterior and interior door handles have held up perfectly.
No sanding needed. Just paint and peel around the edges.
As for the texture, Its almost the same texture as the oem paint on the interior door control panel.
Old Oct 21, 2011 | 04:18 AM
  #196
07JimmyZ's Avatar
07JimmyZ
thanks for the answers, I'll try this stuff soon and let you know how it goes.
Old Oct 21, 2011 | 04:47 AM
  #197
10-E-C-350Z's Avatar
10-E-C-350Z
Originally Posted by sum1finally
Wtf are tolls in relation to trolls?
You gotta pay the troll toll to get into that boys soul
Old Oct 21, 2011 | 12:29 PM
  #198
BSERIEuS's Avatar
BSERIEuS
did you guys remove the door handles to plasti dip them?
or tape off the area and paint while its on the car????
Old Oct 21, 2011 | 12:35 PM
  #199
moose350z's Avatar
moose350z
Its going to be the best if you take them off.
Old Oct 21, 2011 | 01:22 PM
  #200
PrimeX's Avatar
PrimeX
