Ideas for clean install... rear coilover extenders
Old May 27, 2011 | 10:31 PM
SoldzMyZ's Avatar
SoldzMyZ
Default Ideas for clean install... rear coilover extenders
Attached is the pic of what I'm talking about. I wanna of course install the rear panel that covers it and drill a hole to make room for the extenders, but I want to make this look clean. Anyone have any ideas as to how to make this look clean and look good?
Attached Thumbnails Ideas for clean install... rear coilover extenders-img_1171.jpg
Old May 27, 2011 | 11:24 PM
terrasmak's Avatar
Cut a hole in the panel, and cut the extender down till it just pokes thru.
Old May 28, 2011 | 12:14 AM
SoldzMyZ's Avatar
SoldzMyZ
Ok I didn't know u can cut it.... Is it too late to cut it since the coilovers are already installed on the car?
Old May 28, 2011 | 12:42 AM
350ZTheStandard's Avatar
350ZTheStandard
Why would it be tooo late???
Old May 28, 2011 | 12:44 AM
SoldzMyZ's Avatar
SoldzMyZ
Is there a way to cut from the top where the adjustment know is? Also what tools to use to cut.
Thinking I'll use a wire grommet to clean up the whole when the top is cut.
Old May 28, 2011 | 01:32 AM
skakemokid's Avatar
skakemokid
remove one clip from the top panel and it should snap right over it. if you cut through the plastic , it'll hit your back window and make terrible noises
Old May 28, 2011 | 07:43 AM
PowderNismo350's Avatar
PowderNismo350
You don't need to cut it. Just push it down far enough so just the **** is sticking out. I cut a 3/4 in hole in the cover and got some rubber gromits from the auto parts store. Ended up looking sweet when I was done. I'll take some pics later.
Old May 28, 2011 | 12:50 PM
SoldzMyZ's Avatar
SoldzMyZ
It doesn't rattle since the extenders are sorta freely hanging inside the strut bar?
Old May 28, 2011 | 02:47 PM
dcains's Avatar
dcains
If it does rattle, just get an appropriately-sized piece of heater hose, or foam pipe insulation (from Lowe's, Home Depot, etc.), and slip it over the extender.
Old May 29, 2011 | 10:07 AM
PowderNismo350
Ok so heres the pictures.
No there is no rattle. The extenders have like a teflon sleeve on them an they just kinda spiral around in there. I drilled out the second hole in the cross brace thing so the extender's would be further away from the hatch when it was closed. They clear the hatch by like a half inch.
Old May 29, 2011 | 04:49 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
This is something I've been looking at doing for a while now. Do you have any more details on how you shortened the adjusters?
Old May 29, 2011 | 05:58 PM
PowderNismo350
Lol I just pushed them down in the hole till the **** was flush with the cover.
Stevo Z
Oct 3, 2015 09:14 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
