350z Spoiler
Old Dec 27, 2011 | 07:18 PM
masphx's Avatar
masphx
Default 350z Spoiler
Hey Guys,
I have a 2008 350z MT Black. Car came with no factory spoiler. I kind of like the stock spoiler so was wondering where I can get one painted. I recall seeing a site but can't find it anymore?
Mason
Old Dec 27, 2011 | 07:25 PM
jduet's Avatar
jduet
http://www.thezstore.com/page/TZS/PROD/350z02g/30-7297
Old Dec 27, 2011 | 08:34 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
spoilerdepot.com
Old Dec 27, 2011 | 09:06 PM
Old Dec 27, 2011 | 09:18 PM
masphx's Avatar
masphx
Sorry but I'm anti Google search. So anyway, how does the spoilerdepot.com 350z spoiler hold up to thezstore spoiler? Big difference in price.
Old Dec 27, 2011 | 09:52 PM
FliPPER_Z's Avatar
FliPPER_Z
I remember reading a bad review from spoilerdepot a few weeks ago from a my350z member, so watch out for them.
Old Dec 27, 2011 | 09:53 PM
R350Zz33's Avatar
R350Zz33
[QUOTE=masphx;9535213how does the spoilerdepot.com 350z spoiler hold up to thezstore spoiler? Big difference in price.[/QUOTE]
Just Google it I'm sure you will find somthing
Old Dec 28, 2011 | 12:15 AM
EmpireDude's Avatar
EmpireDude
I had a good experience with spoiler depot, others have complained about fitment. The fitment is 9/10, i need to reapply it eventually with new adhesive and ensure the ends stick down a little better or use screws and 3m to mount it rather than just 3m. Paint match is perfect though. Your choice, all depends how much "perfect" is worth to you. You may consider the blitz replica spoiler painted too, the price on it isn't unreasonable (350-400 painted shipped i believe). Pick what works for you!
Old Dec 28, 2011 | 02:53 AM
JCITY's Avatar
JCITY
You can buy one through a dealer if you want to pay through the nose.The 0EM look spoiler is available through many sources.Most vendors,incl spoiler depot,CARID,do a good job in paint match.Your color being black,is pretty easy.In reality,the OEM spoilers that are installed on the Z are not a 100% perfect match.Same goes for the add on mud guards.This spoiler is not a difficult install.However,on the OEM,holes must be drilled in the deck to mount.I imagine,some replicas use only 3-M tape.
Old Apr 18, 2012 | 12:05 PM
sry110's Avatar
sry110
I also got the spoilerdepot OEM-style spoiler, and I would agree with 8 or 9 out of 10 fitment. I have the same issue as you do, with the ends coming "unglued". It seems to happen when the temperature drops below 80 degrees or so. I suspect the material contracts as the temperature drops, effectively pulling the ends away from the deck.
Now, I have mine installed with the 3M tape only, and I made sure to clean and degrease the deck, then apply the 3M Adhesion Promoter stuff to the paint prior to applying the tape. Done it twice now, with the same result.
Have you reinstalled it yet using the mounting screws? I'm thinking that by "pinning" the spoiler a couple inches from each end, as allowed by the provided hole locations, may limit the effective shrink at the ends of the spoiler. But if you found it to be ineffective, that will save me from drilling holes through my hatch.
Old Apr 18, 2012 | 04:30 PM
Driver5's Avatar
Driver5
I went with one off of eBay and I'm pleased with it. Matched the silverstone perfectly. Also had the 3M which stuck like super glue when I applied it. It also gave you the option of drilling. Supplied the screws and everything but I didn't want to drill into my car. It's not that serious. I also wasn't going to spend too much over $100 for a spoiler so this fit the bill.
Old Jul 6, 2012 | 10:22 AM
sry110's Avatar
sry110
I have one from spoilerdepot and have found the material to be very thermally reactive, i.e. it expands and contracts a lot based on temperature and/or direct sunlight contact. When I had it installed with just 3M tape the ends would not stay stuck (due to imperfect fitment) and this would get worse with the thermal growth, i.e. the thermal movement of the part would distort the 3M tape and cause it to separate.
Then I had the bright idea that I would finally install it the "right" way by drilling holes in my hatch and pinning it on each end using some studs and nuts in addition to the 3M tape. Well, it took care of my fitment issue by pulling the spoiler down flush with the hatch. But, the material is still just as thermally reactive as before, and now it's pinned at each end so the growth all goes toward the middle, resulting in the spoiler bowing upward as it expanded in the heat of sunlight.
So now I am in search of an authentic OEM spoiler, which should not have this thermal growth issue (unless someone can convince me otherwise).
Old Jul 10, 2012 | 09:15 AM
sry110's Avatar
sry110
FYI, I stumbled upon this today:
http://www.nissanvillageparts.com/sc...&idCategory=29
These appear to be authentic OEM units, color-matched.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
