Replacing A Broken Key
Old Jan 14, 2012 | 12:37 PM
JedixSole's Avatar
JedixSole
Default Replacing A Broken Key
Hey 350z owners ,
i currently need some help or advice on how to fix my key. the top of it snapped off and i don't have the broken piece to super glue it.. not sure if anyone sells the top part of the key so i can replace it. thanks for your help..
Old Jan 14, 2012 | 02:21 PM
jv350z's Avatar
jv350z
maybe time for a switchblade key mod
https://my350z.com/forum/exterior-an...ey-keyfob.html
Old Jan 14, 2012 | 05:10 PM
jerseystyle's Avatar
jerseystyle
Buy a new key they can't be that much.
Old Jan 14, 2012 | 06:08 PM
EvilCrayon's Avatar
EvilCrayon
It cost $80 to get them programmed and that's not even from the stealership..
OP, you might be **** outta luck but try using a pinvise to drill a tiny hole on the corner exposed and put a small metal ring in place. You definitely don't want want to drill straight through the center cause there's electronics inside.
Waiz's Avatar
Waiz
+1
Thou shalt not use crazy glue for anything
Old Jan 14, 2012 | 06:27 PM
str8dum1's Avatar
str8dum1
take the chip outta that key and put in new key
Old Jan 15, 2012 | 08:20 AM
jerseystyle
SO this is the answer? Let's buy a nice car and then "ghetto rig" a broken key instead of sucking it up and spending $80? Someone should have bought a Honda!
Old Jan 15, 2012 | 08:31 AM
JedixSole's Avatar
JedixSole
i don't mind going to the stealership, i just want it done right than me doing a halfass job on it lol.. but do you guys know where i can buy the key? or the dealer sells it? i just ordered a key fob from ebay too, cuz previous owner didn't give me one, and gave me the broken key^
Old Jan 15, 2012 | 11:30 AM
EvilCrayon's Avatar
EvilCrayon
Originally Posted by JedixSole
Hey 350z owners ,
Did I answer the original post? Yes.
Obviously the key is still useable and it's up to the OP as to whether he wants to replace it or fix it. It's around $130 from the dealership to program a key not counting the actual key itself. I went to a kiosk at the Mall who did it for me on the spot for $80 including a new blank key. Check yelp for local keymakers who program car keys.
You don't fix a lock by replacing the door.
Old Jan 15, 2012 | 11:45 AM
secwind's Avatar
secwind
Do the switchblade key mod, the shell will only cost you $20. Get it cut at any hardware store and stick the existing chip into the new one wala. Here's mine.
Old Jan 15, 2012 | 11:47 AM
KushZEN's Avatar
KushZEN
I second this idea, Here's the tutorial...
Originally Posted by *ICE*
Here is my DIY:
Note: I got the 4 buttons flip key from the guy on G35 forum. Please refer to the OP's first post for more info. Its feels great and A LOT EASIER to swap compare to the 3 buttons.
here is everything i have to get ready for the painless swap...
I took everything apart. There are 3 little screws behind the new key fob, 1 is behind the emblem.
Here is when i get ready to took the transponder chip out of my OEM key. Note: My key is similar to the G35's key, which you can see the hole for the transponder chip at the bottom and you can easily pick it out. Other has the key same as the OP, which mean you have to break the key apart to get the chip
I used the Exacto knife and carefully pick out the chip.
Use super glue on the chip. The chip has to be place at that exact spot or else your car will not turn on.
I transferred the battery holder from the OEM key to the new key, which has slot already make for the easy swap. After that, move the battery over. + sign face down.
I took out the rubber piece that hold the circuit board and transfer it over to the new key. If your rubber piece is dirty, make sure to give it a good rinse to wash out any dirt build up.
Put everything back together. When you have the spring seated correctly, turn it COUNTER CLOCKWISE direction 1 time. It will flip out in CLOCKWISE direction when button is pressed.
I put a few drop of WD-40 on the springs to make sure its can flip out smoothly with no bump. Your done!
Final step is bring your new key and old key to get it cut. Do not try to use the old OEM key with the transponder chip in the new key and start the car. It will not start the car because the transponder chip has to be less than 3 inches from the ignition. Use another key.
I'd RECOMMENDED to get it cut at ACE HARDWARE. Cost is $0 . I tried Home Depot and Lowes but both does not have the key plate for my key. Yours might be different.
Old Jan 31, 2012 | 12:52 PM
JedixSole's Avatar
JedixSole
so i just got a new key fob. but i need a new transponder I'm assuming. i want to have the oem key look not the flip key lol
Old Jan 31, 2012 | 07:26 PM
orangeNblue's Avatar
orangeNblue
I've got a question, does this setup work with the 2008 key as well? I'm curious bc I've gone to the different ebay pages and they say it's compatible through 2007. I just wanted to double check to make sure.
Old Feb 11, 2012 | 11:55 AM
JedixSole's Avatar
JedixSole
i believe so.
Old Feb 25, 2012 | 11:43 PM
JedixSole's Avatar
JedixSole
i just want to know how to have the broken top fixed. idk if i take it to the dealer and if they will give me a new nissan holder thing around the key? i don't like the key fob with the button and key together. not my steez
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
Dymsi
Sep 29, 2015 11:32 AM
