The best way to install a harness?
Old Dec 26, 2003 | 01:39 PM
rucorey's Avatar
rucorey
Unhappy The best way to install a harness?
How is everyone else installing harnesses? I've never put them in before and the only company that sells rails is like $600?!
Have you guys just drilled holes and installed hoops?
Old Dec 26, 2003 | 03:13 PM
John's Avatar
John
Buy a 4pt roll bar and install it the right way.
Old Dec 28, 2003 | 11:13 AM
FCallender's Avatar
FCallender
If you only do occasional track events like drivers schools you can forgo a roll bar.
I replaced the two bolts that anchor the belt and receiver with eye bolts supplied with my 5 point harness belts. This allows you to unsnap the lapbelts after a track session and have complete use of the oem belts.
The shoulder belts hook up very well to the rear strut brace.
Old Dec 28, 2003 | 05:38 PM
EnthuZ's Avatar
EnthuZ
Would you please show a pic of how you attached the shoulder belts to the rear strut brace? I'm not too sure the brace is designed for the loads you're asking it to sustain.
Old Dec 29, 2003 | 10:49 AM
MY350Z.COM's Avatar
Avalon Racing sells a harness bar.
Old Dec 29, 2003 | 10:52 AM
rucorey's Avatar
rucorey
Default What a big harness U have granny!
I looked at that Avalon harness. It seems like big $ for what you get. I'd love to see some pics of others Z's w/ harnesses?
Anyone?!
Old Dec 29, 2003 | 10:54 AM
MY350Z.COM's Avatar
https://my350z.com/gallery/albuo59
https://my350z.com/gallery/albuo60
https://my350z.com/forum/showthread....threadid=41811
Old Dec 29, 2003 | 11:50 AM
Avalon Racing's Avatar
Avalon Racing
Avalon Racing
The fitment and design is critical. Plus the angles at the b pillers is critical to make the bar look right. Then the bar has to be solid to provide the correct stiffness in the event of an accident. We have a few black ones in stock and have been track tested.
$325.00 shipped
Old Dec 29, 2003 | 12:09 PM
DeeZee's Avatar
DeeZee
it all boils down to......where are you going to wear them? if you only intend to wear them at the track, then a harness bar is fine, BUT if you intend to wear them all the time (as i do) then go with the 4 point. if you roll it with just a bar?!?! im not even going to put my harnesses in UNTILL my cage is in!!
Old Jan 4, 2004 | 07:59 PM
commasense's Avatar
commasense
I did this, and I'm very happy with it. Total cost was about $800, including Schroth harnesses. Sparco or Simpson belts would have cost about $200 less (total).
I haven't decided about a roll bar yet, although I'm thinking about getting a Kirk bar.
Old Jan 5, 2004 | 08:55 AM
droideka's Avatar
droideka
Way too many people have dumped it at DEs to make this the least bit reasonable conclusion.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
