Do you need resistors for all LED's?
Old Jul 30, 2012 | 09:05 AM
philliesphan29's Avatar
philliesphan29
Default Do you need resistors for all LED's?
Basically, I was trying to install my license plate LED's and something happened with the BCM so now my parking lights, side maker lights, tail lights, trunk lights, and plate lights are out. I have heard that the problem is I was using cheap LED's that didn't have resistors. I also read somewhere that you don't really need resistors for the parking lights or side marker lights. When I ordered the parking lights I took them to a local garage to get installed and they worked fine without a problem until I tried to install the plate lights, then everything stopped. I have always had one of the side marker lights out and I am just now trying to replace it but I'm going to wait because I don't want it to mess up the BCM again if I don't use resistors. The only lights working in my car now are dome lights, headlights, hi-beams, brake lights, and reverse lights. I wanted to get the BCM fixed but I wanted to know if parking light and side marker LED's need resistors because the parking lights worked without them until the whole license plate situation.
This is kinda confusing so if you need more information, just ask. Thanks
Old Jul 30, 2012 | 01:23 PM
bmccann101's Avatar
bmccann101
if they flash, you need resistors.
If they dont, you dont.
Old Jul 30, 2012 | 04:03 PM
philliesphan29
Alright, well they don't flash but apparently the reason I blew out my Body control module is because I didn't use resistors on the license plate lights. But thanks!
Old Jul 30, 2012 | 04:07 PM
bmccann101's Avatar
bmccann101
makes no electrical sense.. LEDs decrease impedance and therefore ameperage and at the same "static" votlage levels.. the opposite is what blows things.. but by decreasing said voltages etc.. the flashers dont work correctly.. but the lack of draw and electrical lifting that the LEDs allow should not ever blow anything.. just the opposite.
Old Jul 30, 2012 | 04:26 PM
philliesphan29
Hmm maybe I just used the wrong wording. I took it to a garage and they told me to see my dealer because they didn't want to touch the body computer. But we found another garage around here with more experience and were gonna go there tomorrow. If they can't then I'm just gonna go to the dealer. If I have to buy a new BCM I'll buy it, take it to Nissan and have them install it and also install the new LEDs in the license plate and side markers. Sound like a good idea?
Old Jul 30, 2012 | 04:28 PM
122554's Avatar
122554
Shouldn't have caused a problem. Try resetting the BCM by disconnecting your ground for 15 minutes.
Old Jul 30, 2012 | 04:35 PM
philliesphan29
What does disconnect your ground mean? Unplug the BCM for 15 then plug it back in?
Old Jul 31, 2012 | 03:21 AM
122554's Avatar
122554
Take the ground off the battery
Old Jul 31, 2012 | 06:11 AM
DFW Z33's Avatar
DFW Z33
I am salad
No, it makes sense. with decreased impedance, amperage increases, which will blow fuses and electrical components.
An easy formula to tell how much current you are drawing is Voltage/Impedance, or in your case since this is a DC loop, Voltage/Resistance. Not only will not having a resistor cause it to draw a lot of current, it will cause your LEDs to fail with a little time. You will blow every LED light.
Find out what current and voltage the LEDs need (usually 20mA @ 1.7V). Using this info, take (Max battery voltage - LED voltage)/(LED current) = resistor value.
Assuming:
LED = 1.7V 20mA and Max battery voltage = 12.5V,
(12.5-1.7)/.02 = 540 Ohm resistor.
I am an electrical engineer and have done LOTS of electrical work on my Z, so if you are still having issues, or want clarification, feel free to PM me or post back here
Old Jul 31, 2012 | 11:39 AM
Deteria's Avatar
Deteria
Assuming:
Not really related, but 2006 didn't have Carbon Silver, just FYI. Yous got Silverstone. XD
Old Jul 31, 2012 | 02:19 PM
DFW Z33's Avatar
DFW Z33
I am salad
I was under the impression 2006 was the first year to get Carbon Silver. All i know is, I know the difference between Silverstone and Carbon Silver, and my car is definitely Carbon silver
Edit: although, I am no expert in 350z model colors, so its possible that I am wrong, and the previous owner got a paint job that looks similar to carbon silver... however I doubt this car has ever had an after market paint job
Juztin
Nov 22, 2015 07:03 AM
davidm350
Oct 31, 2015 02:28 PM
Mw870
Oct 2, 2015 08:23 AM
350z82
Oct 1, 2015 06:25 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
