Nicest Aftermarket Pedal Covers?
Hey, i'm looking into buying an aftermarket set of pedal covers. I have a manual transmission, and my pedals look terrible compared to the rest of the car? What do you guys have or suggest that looks good? Thanks!
A large percentage of car guys don't realize how much pedal spacing, texture, and movement affect the driving experience.
My base came with the rubber covers and after 2 months with the oem alum units I concluded they were even worse for traction (especially with wet shoes).
I had a custom pedal set made by SRP pedals and could not be happier. The pedals are drill and bolt thru, allowing you to shift the pedal spacing about 1/2" side to side.
I elected for the extra wide gas pedal, coupled with the brake pedal shifted 1/4" to the right, makes heel - toe braking and all around brake to gas pedal transitions a breeze.
http://www.srpracing.com/
I have the Autovation pedals. They look great and they were easy to install. Their website is www.autovation.net
Hey Ian what finish did you get them in for best traction even with wet shoes?
See, I'm alittle particular with the holes on the pedals. I don't really like how there are machined holes for looks, but then there are other holes that are for mounting that look like there just set in between all those other holes. That's why I'm leaning towards this pair, that you use any of the holes on the pedal to use.
Here's what i'm leaning towards;
This is an example of the holes I don't like;
I think the first image looks just that much cleaner.
