05 aftermarket oem headlight beam issue!!
Whats up My350z im preety new on here figure ill post this very important question thats bothering the **** out of me.....
i just got my 05 white 350z back from the body shop they installed OEM style aftermarket headlights assemblys with 8000k HID bulbs D2R that i previously had in there...when i had the old/original OEM headlight assemblys in and the new bulbs installed the headlight beams were perfect even when i adjusted them up!!!...(im sure other owners had low beam issues not being able to see futher than the headlight beam) anyways the aftermarket headlights are in and operating well and i have adjusted them countless times when im behind someone it always seems the driver side headlight is pointing higher than passenger side also the beams themselves are not together landscape wise with the headlights projection themselves hope i made that easy to understand....really need some help and or advise on what to do maybe i need to go inside the assembly myself n move them or.... please help thnks ALOT
Only thing I can thing of if everything is straight is the bulb might not be sitting straight or your light is defective... keep the look up for the 06+ lamps those are the best you can put on a z. Contact the vendor and let them know the issue. It'd ruin my night everytime id turn them on and saw that horseshoe light
@donj....LMAFO JAJAJA. IT RUINS MY NIGHT EVERY SINGLE TIME MAN I BE PISSED..it looks like back underthe wheel well I go to check these bulbs if that don't work hunting ill have too do with the body shop to see where dey ordered it n **** smh long *** process or just sell em n then look for the 06 headlights....any idea where to get those cheap?
