Connecting 06+ headlights onto 03-05 hid harness?
Old Mar 15, 2013 | 02:34 PM
kiuso00's Avatar
kiuso00
Default Connecting 06+ headlights onto 03-05 hid harness?
Hi guys , i hope that im posting in the right section since this will be my first one , this is my dilema , i bouth a set of used 06+ oem headlights for a very low price ($240 with shipping ) , they come with the ballasts and bulbs but the previous owner cut the wire harness to use it on another project , i have 03-05 hid on my car at the moment , the question is ... can i use my harness on the 06 lights ? I dont mind having to cancel a bulb or two since i will have true bi xenons now , please help , thanks in advance
Old Mar 15, 2013 | 06:47 PM
kiuso00's Avatar
kiuso00
Nothing ? Bump!!!
Old Mar 16, 2013 | 07:56 PM
kiuso00's Avatar
kiuso00
99 views and not even one comment or answer?
Old Mar 17, 2013 | 04:41 AM
350Zdj's Avatar
350Zdj
I dont know what's done on that headlight but when I swapped from 05 to an 08 i did not have to modify anything. It was a direct install.
Old Mar 17, 2013 | 05:26 AM
kiuso00's Avatar
kiuso00
Thanks for the reply , the thing is that the headlights didnt have the wiring harness , it brought the ballasts and all the bulbs but no wires , thats why i want to know if i can use my current 03-05 wiring on the new headlights
Old Mar 17, 2013 | 06:42 AM
ZMoneyPIT's Avatar
ZMoneyPIT
No you have to buy the 06+ harness. It's like $40 so you're still getting out ahead.
Old Mar 17, 2013 | 07:01 AM
kiuso00's Avatar
kiuso00
Thank you , do you know anybody that has a pair to sell or any place where i can find them?
Old Mar 17, 2013 | 09:08 PM
kiuso00's Avatar
kiuso00
Any other ideas or thoughts?
Old Mar 18, 2013 | 01:32 PM
ZMoneyPIT's Avatar
ZMoneyPIT
Go search up 06+ wiring headlight harness for the 350z. You'll find it for like $40.
Old Jul 17, 2013 | 06:08 AM
RENFRO's Avatar
RENFRO
Can't find these harnesses anywhere. Bump.
Old Jul 17, 2013 | 06:14 AM
iideadeyeii's Avatar
iideadeyeii
You can splice it in to your harness and use the plugs off your headlight. Just make sure you do it correctly. If you do not know how then just buy a new harness
Old Jul 17, 2013 | 06:33 AM
RENFRO's Avatar
RENFRO
All I should need to splice is the high beam connection, correct?
Old Jul 17, 2013 | 08:12 AM
mr. sparco's Avatar
mr. sparco
Computer power harness.
This should be correct as I drew this on my knee back in 2006.
Figure out car side harness first, then trace each wire on the 06+ headlight. See which matches up, connect low beam car side to low HL, parking lights car side to HL etc. You can also make your own harness, just need a simple power harness off a computer. One of the plugs on the 06 will not be used, everything will work perfectly without it, even high beams.
Old Jul 17, 2013 | 08:24 AM
RENFRO's Avatar
RENFRO
This is why I started a separate thread. I don't have any 06 wiring whatsoever. I have blank housings. Will all of the wiring off of my 03 HID swap over to the back of the 06. Splice in the power from the halogen H7 connection to the solenoid and be good to go?
Old Jul 17, 2013 | 08:33 AM
mr. sparco's Avatar
mr. sparco
The harness might need to be adjusted or changed, I don't recall. If it fits then you are good to go. The high beam shields will retract once wired into the 03 harness. Just make sure everything is the correct corresponding function that matches the harness on the car side.
Old Jul 17, 2013 | 08:36 AM
RENFRO's Avatar
RENFRO
Yes exactly. FINALLY someone that understands what I'm trying to do. My only remaining question is if the plastic base plates on the turn signals and DRLs from an 03 will screw into an 06. If the bulbs will physically go into the new housing. The wiring really won't be a problem for me. It'll literally be tapping 2 wires for the high beam shutter, and 2 wires for the upper corner LEDs from the lower corner DRL that I don't intend to use.
Old Jul 17, 2013 | 08:50 PM
mr. sparco's Avatar
mr. sparco
If the bulbs don't fit, replacement bulbs can easily be sourced.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
