Ignition light conversion
First off, before i begin, i searched any "key word" i could think of to see if this has been mentioned already.
I have an '04 and have moved up to the '06 parts. All but the interior light around the key/ignition.
Can someone chime-in and inform me of what ll needs to be changed/added? I'm assuming a bit of wiring fab work will be needed as well.
Nathan
(404) 915-0043
Nathan
(404) 915-0043
I have looked at this conversion as well for my '03 and not found any way to make it work. Too bad, as it was another nice upgrade for the '06-08 mid-model interior change that has been mostly completed in my Z.
I will be doing that in a bit, if you want to wait for me to figure it out. If not, then you should be able to tap into the wiring for the dome lights.
