Amber/Yellow LED Fog Lights to Replace Front Reflectors?
on
Does anyone make a fog light kit that replaces the front reflectors?
I've searched and found nothing. The closest I got is this from iJDMTOY, which I bet most of you guys have already seen:
2003-05 Nissan 350z Switchback LED Daytime Running Light Kit — iJDMTOY.com
As this kit emits white light which turns amber when the turn signals are activated, I'm wondering:
- Can this be wired such that it ONLY emits amber/yellow light w/o the turn signal function? In other words - simply as an amber/yellow LED fog light kit?
- Is there any other similiar kit out there that outputs amber/yellow light instead of white?
If I were you, I would get some HD amber LED strips from Diode Dynamics, open up your stock reflectors or get some clears and put the LED strip in there. Wire it up to either your parking lights as a trigger or an accessory so it would function as a DRL.
dkmura (02-12-2021)
I have ijdm led sidemarkers for several years with zero problems - it is a good product.
You can rewire them for sure , but trust me - you’ll like them as they are.
on
Thanks for all the info.
I prefer amber/yellow over white for fog lights; bright white defeats the purpose of fog lights.
I'm surprised that there aren't aftermarket fog lights to replace the reflectors for the Z33; especially since the Z34 adopted such styling
The early Z33 bumper design isn't very conducive to forward facing light. Those reflectors are angled to the sides, if you look at the IJDM and others for 03-05, they poke out of the bumper to face forward. They look wonky especially when off. The alternative is to place fog ligths in the radiator opening, but you could do that with any generic light at the expense of radiator intake real estate.
Not to argue semantics, but being a lighting nerd, I have to clarify some things. The sidemarkers are not fog lights. The clear white strip that you see on the Z34 front bumper is not a fog light. It's a sidemarker and a daytime running light. As Freise mentioned, you can get any generic fog light kit, LED light bar, etc. and mount it on the bumper and that would be a fog light. A true fog light beam pattern will be wide and not as focused as a driving beam. A DRL or illuminated side marker is not going to have a wide beam pattern like a fog light. You will not be able to install fog light in the OEM sidemarker opening on your Z33 front bumper.
World Famous Z
08-29-2007 09:42 PM
ares
03-09-2004 01:26 PM
